I have an Open/Close sensor that is reporting battery life (in Events section of my IDE) between 10 to 15 times a minute. I have a total of 4 in the same room, and this is the only one doing it. It’s reporting it so much that the battery has drained 50% in 12 hours.
I noticed it when I first installed it. I replaced the batteries and it happened again. I performed a factory reset and included it in my network again at the point of installation (I thought it might be constantly searching for a signal…). I then performed the Z-wave Repair Utility a few times.
I’m still having the same result. Any thoughts/suggestions will be appreciated…
I’m sorry, I should have been more clear. This is the 3rd set of batteries (which I pulled out of a sensor reading 100%). Below is a snippet of what was happening when the 2nd set of batteries was installed (Same switch, just different label).
