I’m using the @iquix Tuya Window Shade edge driver for my Zemismart Zigbee window shade motors. I paired the first one and it works perfectly. However, when I paired the second one, it says it’s window shade: 0% “Closed” when actually it’s open. It also doesn’t stop at the programmed stops. The stops are programmed correctly and the shade works perfectly with the remote control.
Is there any way to “tell” it that it’s actually open?
Yeah, I did think about that issue, but my motors were on the same side. I did end up fixing it by deleting all limits, deleting all remotes, deleting the device from the hub, re-pairing the remote, re-setting the up and down limits, then re-adding the device to the hub. After doing this, it mostly worked except for the down limit was somehow reset to being 20% lower, so I had to delete and reset the down limit, and now everything works perfectly.
I’ll be adding one more motor that is on the opposite side and I may have to use the “reverse” feature.
