Open a Drain or Pump Water out of a small Bowl?
I am trying to come up with an idea to drain a bowl or basin and can’t figure out any sort of smart device/contraption to do this with. I have figured out how to get water into a basin, with an always on hose spigot, a sprinkler valve and an on/off smart controller… but I can’t get the basin emptied via automation.
Hoping anyone has some ideas? Thanks in advance for any help!
There are two main ways to do this.
1. Pump the water out
If you look at the design for any pet fountain, you’ll see that these are most commonly set up with a recirculating pump. If you choose to have that pump transfer the water to another container, then you can use it to empty the original basin, that’s typically going to be the easiest, although obviously it’s going to require electrical power but I assume that’s OK since pretty much any automation will. So to empty the basin you just turn on the pump.
2. Provide an actuator for a gravity drain
The other alternative is a basin with a drain that has a sliding drain cover and then you use an actuator to open the drain. Think of a bathtub and then automating the open drain lever.
This is doable, but often turns out to be more expensive than just adding a pump. However, it’s a good way to completely empty the basin, which is hard to do with a pump because the pump usually needs a small amount of water to keep it primed.
For example, here’s a typical livestock waterer.
See the drain plug on the bottom? Add an actuator underneath to move that and you can drain that way.
I believe there are some commercial versions which do have this function automated, but they tend to be designed for dairy farms and are very expensive since they have to be durable enough for cattle.
So depends on the details of the use case. What exactly are you trying to do? How big is the basin and how empty does it have to get? And how durable does it have to be?
I’m thinking of doing a style of automatic dog bowl waterer. The issue with these bowls is that they keep water in them all the time and if the dogs are not drinking it constantly, then the water becomes stagnant and starts to form algae or residue.
So the plan was to somehow create a dog bowl that drains based on a timed automation and then after so much time, it fills from a hose valve. I could actually use an automatic waterer and simply shut on or off the input valve based on a set amount of time, which would be predetermined after the dog bowl can completely drain. So it would be constantly be pumping fresh water into an empty basin instead of pumping fresh water into a basin that has day old water for example.
Ok, The problem is that even a gravity drain will leave a little mist of water in the bowl so algae may form anyway. It depends a lot on your local climate. If you were in Arizona, it’s not going to be a problem. But if you’re in Michigan or Florida, the humidity becomes a factor.
I think most farm systems rely on recirculating the water rather than draining the basin, as that tends to keep it fresh. There are lots of recirculating pet fountains available, some designed for outdoor use. You also need to keep the basin in the shade as sunlight will encourage algae growth.
I’m sure you could build something that would open the drain, I’m just not convinced that that would really serve the purpose.
A non-automated solution that many people choose for this use case is a Lixit nozzle. If you know how a hamster water bottle works, this is the same idea, but you attach it to the faucet. There’s no bowl and no standing water, so algae not a problem. Most dogs that are tall enough to reach it get used to it very quickly, and it will cost you less than $10. The Amazon reviews will give you a good idea of how different people use it.
Just a thought, but a few 12v solenoid valves might work, coupled with a few 12v switches, or AC switches powering 12v power supplies.
These valves are typically closed until voltage is applied, and return to closed after voltage is removed.
The drain could use gravity to drain, and the water supply could be on a timer or configured to shut off with a water sensor.
I was actually thinking something similar to the above mentioned gravity option. Even if there is a small amount of water in the bottom of the bowl, I think that proves to be better than having a bowl full of older water.
I have had automatic Waters in the past for smaller dogs, and I find that they still develop a residue over time because there is still a basin that water sits in and it is not completely flowing all the time.
I don’t doubt that any small water that doesn’t get automatically drained would evaporate, but I feel like being using gravity or solenoids or even the pump would work better as far as reducing overall amounts of water.
The Lixit I have seen before, but I’m not sure how it would work for several dogs, especially larger ones. I may look into that just to see how it works and the amount of water flow that comes out, but I have dogs that will drink half a gallon of water at a time when they have been running around and I don’t know that that little device would be adequate for their needs
If you do want to go with a drain cover that can be actuated from underneath, @johnconstantelo or @ogiewon might have some ideas. Slide covers are typically the easiest to automate. And lift the basin up on a pedestal stand to hide the actuator. or get an actual sink basin with a drain lever and actuate that. :thinking:
Yeah I was thinking of some sort of sink popper drain adapted to an open/close valve instead of a popper but outside of simple on/off automation with smart switches, I’m completely dumb to any custom servo type stuff.
Wouldn’t mind learning but I just don’t know anything about that all present day that would aid this particular solution.
The simplest kind of linear actuator is just a tiny rod that moves forward and then back again. It’s sometimes called a push bolt. These come in all sizes from about 3/4 of an inch to four or 5 inches. Probably the most common DIY project with them is to open and close a cabinet door. Or for an automated shelf that slides forward and then back again. So again, if you get a slide bolt mechanism, or a lever that pushes back and forth, that’s pretty easy to automate.
There are a couple of project reports in the community when people were making cabinet doors that opened automatically that are the same idea.
You also see them for some kind of cabinet door locks. Just a bar slides across and then that keeps the door from being pulled open. It’s a version of a deadbolt.
(I made one of these with a potato battery and a nail back in third or fourth grade. It was pretty cool. are used it to make a lock on a treehouse door. :smiling_face_with_sunglasses:)
As far as the tiny ones, one common use case is for the door lock on a car door. It’s really just pushing a rod up and then pulling it down again.
Anyway…Firgelli is a popular brand and people have used those for projects in the past.
Here’s a really old post from about five years ago, but start at this post and read down and you’ll see how these kinds of projects are put together. Different people in the thread are working on very different size projects, but the basic idea is the same and you should learn a lot from it. :smiling_face_with_sunglasses:
Also, go back to thinking about a bathtub drain. This is a helpful article.
Obviously the ones where the control is above the waterline or below the basin, that is, not underwater, will be much easier to automate.
A trip lever should be pretty simple to automate, you just want to push it up or down. Here’s an example of what that part looks like. This particular one is from a very fancy high-end line and it’s very expensive, but It has the best picture. This style is pretty easy to automate.
Again, though, I would just start with the lixit and see if it works for your dogs. Sometimes simple is all you need. :wink:
Thanks for tagging me @JDRoberts . All I can really think of would involve devices that are large compared to these watering solutions. A zigbee/zwave valve could be used to act as a drain when opened, but these are not small devices and the end solution would look pretty bulky IMHO. I suppose an actuator could be used along with a device like the MHCOZY 1 Channel 5V 12V ZigBee Smart Relay Switch or FortrezZ’s Mimolite.
As suggested by @JDRoberts, I went low-tech and made this. I have yet to test it as I’m letting the PVC cement cure a bit more. If this doesn’t work out how I envision, then I will probably proceed with my more automated solution.
My wife doesn’t like the idea of dogs drinking from a gerbil nipple, but we shall see. :joy: Also, we have several different height dogs hence the different nozzle heights.
Looks good! :sunglasses: Lixit nipple valves are commonly used for pigs and goats, they have a flow rate of about a quart per minute so usually plenty for even large dogs.
One of the Amazon reviews is from a Doberman breeder who uses it with multiple dogs and likes it because the water’s always clean.
Conceptually I think humans have to get used to the idea, but the dogs seem happy with it. :dog:
Also, although this is called a nipple valve, it’s actually just a push lever and the water flows around the stem. It’s not like a baby bottle.
This video from the manufacturer shows you the flow rate. The dog pushes the valve with his/her tongue, and then the water flows into their mouth around the valve. They don’t have to suck or lick the valve to get water and it’s not just a drip.
Redirecting...
Well the “nipple solution” didn’t work out, primarily because I didn’t seal the piping correctly but also the dogs had a bit of a learning curve. Quite possibly because I didn’t remove the old bowl and I think they got confused. This is still an option but I need more pipe before I can test again.
So in the meantime, I made the automated solution. It utilizes gravity and a normally closed solenoid to drain and the standard float valve/irrigation valve to allow water to come in.
That looks pretty darned cool… lucky dogs!
lol I see what you did there! I’m going to put the entire feeder in some sort of bucket or container for it to sit on while hiding all of the piping and allowing drainage. Not sure how it’ll all work out yet, but I figured the only way to get it working the way I want is to start experimenting. With a Routine, I can easily open the solenoid for X seconds(however long I determine it takes to drain the bowl), close the solenoid and then open the float irrigation valve. I might even be able to leave the float valve open all the time to keep the bowl filled for the duration the dogs are outside… then close it when it’s time to drain/refill the bowl.
Honestly I was thinking it’s actually a reasonable use case for people with pets that have access to outside but can’t tend to them 24/7 due to work or whatever other reason.
So to follow up:
I’ve gotten my device built but when I tested water gravity draining out of the bowl, the solenoid was apparently for pressurized water/air because when I opened the drain solenoid, water trickled out. So I’m changing my plan to test one of two options:
  1. A 12v irrigation valve instead of a 12v solenoid (guaranteed to work, slightly bulky to conceal)
  2. A small water fountain pump that has a specific inlet that I will run tubing to from the drain bowl (Not positive will work, but if so, will take up less vertical space for water drain, which is ideal)
I’m even playing around with including a 12v motion sensor to the inlet valve so as soon as a dog walks up to the bowl, it starts filling up and I can just drain it at set intervals… rather than having to smart automate two different components.
I ordered everything Same-Day Amazon so will post an update later today if anyone is interested :slight_smile: Just figured with the nature of the Community it would be worth sharing progress as the concept evolved. Honestly, I’m excited for the progress and evolution it’s making… it would be the first ever actual “invention type” device I’ve came up with lol
The insight on the valves alone is valuable enough to me. I have too many ideas without first-hand knowledge of the components.
Thanks for sharing!
Here is my basic gravity setup. I am still waiting for a second 12v transformer, and I am going to play with a motion sensor for the inlet.
So the garden hose connects to the top valve connected to a float valve inside the bowl. Either motion(to be experimented with) or a routine will trigger Switch 1 to open the top valve to fill the bowl. Once filled, either after so much time, the bottom valve will open, triggered by Switch 2 HOPEFULLY letting gravity drain the water out.
I also still have to experiment with a small fountain pump connected to the bottom of the bowl, but it’s not here yet :slight_smile:
