[OBSOLETE] Lock Manager
Hi ERIK
I trying the Lock Manager to my ST im kinda new to this and im not so technical. i followed the instruction to of the lock manager but the add user code not showing to my app tried to look in the SmartApps. please help me improve my lock. im using Schlage Connect BE469 Z-wave deadbolt, the Alarm works, Auto lock and Lock and leave work perfect.
Just want to add and delete user via app. is that possible?
Thanks in Advance
did you establish OAuth through the IDE?
Sounds like you donā€™t have the custom device driver code active on your locks. You must install the custom Device type handler for your lock, and then activate it through your device list on the IDE.
Can you make sure you only have 1 instance of the app running in your location? Go to Automations, then ā€˜Smart Appsā€™ . If you have two or more, they will interfere with each other and cause issues.
Sounds great! Iā€™ll see if I canā€™t debug this issue. Iā€™m surprised that you get a log of ā€˜locked by keypad.ā€™ I didnā€™t think that the 910 supported that. I THINK everything should log as ā€˜manual lockā€™
Erik-
Thanks for responding, I only have one. I do have two locks on it, a kwikset (on another door) and a schlage, using the same code, not sure if thatā€™s an issue?
Maybe. Are both online and working? Itā€™s possible that if 1 of the locks is MIA, the code could go into a disabled state because of it. Iā€™ll try looking into that scenario this weekend.
I believe I do have it installed and activated. That is the part that is on page 7 of the guide. ā€œNote: If you have a Schlage touchscreen lock, you may choose ā€˜zwave-schlage-touchscreen-lockā€™ all
other locks select ā€˜Z-wave Lock Reportingā€™ā€ I selected and published the Z-wave lock reporting.
And then, I go to activate the lock but donā€™t know exactly which ā€œtypeā€ to
choose. In the guide it shows ā€œz-wave lock reportingā€ but that is not available. There is just ā€œZ-wave lockā€ and"Z-wave lock with reporting" I have tried both with no progress.
Just to make sure ā€¦ did you scroll to the bottom of the list? Custom handlers that youā€™ve have added are usually located there.
I bet thatā€™s itā€¦ I remember reading that and scrolling to the bottom, but not seeing it. I then went back up and selected the next closest thing, thinking that it may have been updated since publicationā€¦
I have 5 Schlage Connect locks and have been using Erikā€™s old User Lock Manager app for several years. Today I decided to update to the new app. I deleted the old app and installed the new app using the guide. I added 1 lock using the ā€œgaryd9 : Z-Wave Schlage Touchscreen Lockā€ device handler pulled down from the GitHub repository. It saw the lock status and the current codes in the slots. I added my 4 users in and it doesnā€™t seem like it tried to overwite them or anything. Then I added a brand new 5th user. When I go to the lock info I see the personā€™s name in the slot but no code has been set. The IDE logs show the attempt to set the user code in slot 5 but it seems to be in a loop. After a while I go in and look and for Slot 5 it says ā€œController failed to set user codeā€. I am also unable to control the lock from within the app. If I unlock using my own code physically using the keypad, under the Recently tab for the lock I can see the unlock happen and the associated routines run (hallway lights turn on), sends SMS, etc. So it seems like I have some kind of partial communication with the lock. Iā€™ve disconnected the batteries and put them back in after 30 seconds and nothing changed. Iā€™ve tried doing a Reset User several times now in an effort to set the code but I seem to be stuck in this loop. I attempted to added another one of my locks and itā€™s the same issue, Slots 1-4 existing are good. Slot 5 goes into a loop. Any suggestions?
Thank you sir - this was a great with great instructions.
Hi guys, sorry originally posted this in the wrong forum, but I was curious if itā€™s possible to have a user code be active in multiple modes? When you pick a user then go to ā€œschedule (optional)ā€ it has an allow access only when in this mode. What if you want a user to be active in several modes including ā€œaway, home, vacationā€ but donā€™t want it activated in ā€œsecure nightā€ or something. Is there a way to have a user code be active in multiple possible modes instead of just one?
Many Thanks!
  • Savio
Just installed Lock Mgr with my Yale 220. Great work - thank you!
I have three remaining questions:
  1. i do not see the mastercode - it does not reserve a slot? and it is not possible to edit through the app, correct?
  2. when closing the lock I get notifications stating which user did it. this is sonewhat confusing as it could be any user or non user buy just putting their hand on the touchpad, Is it possible to change that behaviour?
  3. Is it possible to disable notifications when a device/user is present ? Similiar to ā€œdo not run action if user is presentā€
Thank you so much!
D
jacintoj, How were you able to get the zigbee YRD210 working with code management?
First, it was setup with default smarthings DTH that is lacking codes. So Iā€™ve installed the DTH from jhamstead ([DEPRECATED] - Universal ZigBee Lock DTH with Lock Codes) and applied it to the lock. It made bunch more features show up, including disable and enabling the keypad.
Then I installed the Lock Manager from this thread. When I add the lock inside lock manager, nothing shows up referencing the codes other than a notification if an incorrect code is entered n-times.
Any help would be greatly appreciated.
Unfortunately, Iā€™m not clear on what you are asking. Make sure all of the additional lock manager child apps are installed. If everything is installed correctly, you should see ā€˜code added for user Xā€™ in your recently tab for your lock.
Thatā€™s correct, Mastercodes on [all?] devices are not accessable through ZWave protocol.
Are you saying that you get a notification that a particular user locked the lock? Is it always user 1?
Not at this time, but thatā€™s a good feature request.
No, but itā€™s a feature thatā€™s on the olde to-do list.
Your lock could be in a state where it thinks it knows what the codes are in 1-4 but it doesnā€™t truly know. Thereā€™s a problem right now that Iā€™m trying to solve that when you install Lock Manager in a non-null state, what you should be really doing is doing a full factory reset on the lock to clear any codes, that way there are no conflicts on the lock that would cause issues.
Follow the Schalge user guide to clear all codes from your lock. This may also delete the Zwave pairing, so you may have to add it to your SmartThings platform again, and ensure that itā€™s set to the correct device handler in the IDE. After that, program the codes in from a fresh start and you should be well on your way.
I figured it out. I was doing everything rightā€¦ but I wasnā€™t the owner.
I was setting this up at my Dadā€™s lake house, and he added me as a user. So I was in the IDE doing all this under my account. ~95% of it all worked as this ā€˜secondaryā€™ user in the IDE. I got a clue when the Live Logging was completely empty.
@ethayer: No, random users that used the lock before. I get notification like ā€œuser xx has locked the doorā€. I did not yet figure out what triggers the different names, yet. In any case it seems odd as locking does not require a code and therefore cannot be attributed to a certain userā€¦
Hi,
I believe I did everything you did but my final step was to hit the Force Reconfigure button. What I found that this did was wipe out all the codes that I had manually configured on the lock. I went ahead and setup the codes on the Smartthings app and tested everything successfully after that. Hope this helps.
