[OBSOLETE] Denon Network AV Receivers
yes, I didn’t get any errors that upload didn’t go through from Ide to Github, but I did have ide/Github Integrations problems today. I’ll double check
Hi, I have just enabled this Device Handler and it sees my AVR3311. Is there a way for me to use the HD Radio or other inputs? Also, I believe I have the latest version, but I don’t see how it controls my Zone 2 volume or toggles it on and off. Thanks!
for some reason i do not find my Denon 3200 receiver… i guess i can’t have it all…
my Denon reciever is detected by the Media Renderer though so i just thought it was odd…
oh well, thanks anyways for helping out…
HD Radio is not enabled. But I can certainly put it in with the next release along with some tweaks to the Zone2 … early next week…
I added the repository. I see the device handler in the IDE. I do not see anything new in my list of things (My Home section, Things tab). Am I looking in the wrong place? Do I need to add something in the app or IDE for it to show up?
You are close…Now you need to go to Devices and click add + Device. Select the Denon AVR as the type, pick your location and Hub, then click Create…
Thanks! Working with my AVR-1613.
Is there a way to change the labels on the inputs without editing the code in the IDE?
No, those fields are read only. They cannot be programmatically overwritten. (I tried) :smile: You need to change them in the code
Not to derail the topic too much, but how possible is it to modify this to work for Pioneer receivers? Is it possible to take this code and adapt? I haven’t delved into code yet (besides pulling from GitHub and using the IDE to set up SmartApps and DTH) so I’m wondering how to start on this. Sorry if this is inappropriate for this thread but I’d love to do these controls on my receiver!
I just got my smartthings hub this week and have been working to get everything setup. I came across this app and just installed it and it appears to be working fine with my AVR-X2100W. Thank you for putting this together!!
A couple of quick questions
  • Where is the on/off button on this thing? Once I turn the receiver on, I can change inputs, volume, etc., but can’t figure out how to turn it on.
  • My receiver comes with Spotify connect as well as Pandora, which are my primary sources for music. Would it be possible to get these added as input options?
Thanks again!!
I cannot change the icons of the standard tile, so the on/off is Play/Pause (when you click on the top tile).
It is possible to add internet Radio…
I don’t think is possible, but I believe some else did a Pioneer handler.
I there anyway to get Alexa to turn my stereo on/off with this?
To turn it on/off, all you need is to authorize the device with official Alexa ST app. To control volume and change inputs use EchoSistant.
My Alexa must not of had her morning coffee yet when I first tried to have her turn it on & off. She’s working 5 minutes later. [quote=“SBDOBRESCU, post:35, topic:80834”]
To control volume
[/quote]
She can also control volume and I don’t have EchoSistant, yet. Thanks for all your hard work.
Did you create a virtual dimmer to control the volume? The advantage of using EchoSistant, is that you don’t have to use awkward commands. You just say Alexa set the volume to x IN the Livingroom or the TV is too loud or not loud enough and Alexa adjusts the volume regardless of your device name. (You do have to create a room - Profile- in order to use the connector IN). Else, you would need to say: Alexa tell Home to set the volume to X OR tell Home the TV is not loud enough.
No, my receiver shows up as a “SmartThings Device (dimmable)” in the Alexa app. So yea, I have say “stereo, 50%” for example to change the volume. [quote=“SBDOBRESCU, post:37, topic:80834”]
[/quote]
I know. I’ve got a Sonos Connect on my receiver & a Sonos Play (coming on my birthday) & 4 Echo devices around the house. I’m kind of slow when it comes to that IDE stuff. But my goal is to get EchoSistant up & running in the next month.
Nice, with your gear, you will really like EchoSistant. Let us know if you need help getting started. Jason @bamarayne and I are here to help. Happy early Birthday! :smile:
I tried to attack the zone2/3 beast for the past couple of hours and got nowhere besides successfully powering on via some shell commands found here
My idea was to make 3 separate DHT’s (main zone, zone2, zone3) and associate them with 3 different instances to have control for each.
I cannot for the life of me get zone 2 or 3 to even power on let alone do anything else.
http://[Marantz_Network_IP]/MainZone/index.put.asp?cmd0=PutZone_OnOff%2FON%26ZoneName=ZONE2
This command works if I run it on my machine.
Can anyone point me in the right direction?
I have an avr3313ci
I was looking through the webgui with some dev viewing turned on and noticed for zone 2 my /goform/ link is
http://AVR-IP/goform/formMainZone_MainZoneXml.xml?_=1490674194137&ZoneName=ZONE2
and I also see this link
AVR-IP/Zone2/index.html.init.asp
