Notify when door is unlocked for more than X minutes
Hi @geko, i tried going to the new link in github but the page is not found. Could you please check if everything is ok?
Thanks in advance
Thank you so much geko!
Found what I was looking for :slight_smile: thank you @geko
I just installed this and set the specific mode to Away, but it seems to ignore the mode. Any help on getting that piece to work? Ideally only want to check if unlocked and away.
Installed a door sensor at the same time in installed the zwave lock. Set up a auto rule to lock the door X time after its closed.
