Automation help needed: get a text when door unlocked?
Hi there. After having to get a new V3 hub as my one from May failed I would appreciate your assistance with automation programming.
  1. let’s say I give a friend his own code to open the lock. Is there a way to have a text sent to me that will not only tell me the lock was unlocked but the name assigned to the code is ?
  2. per below picture when I unlock the door I get several texts including the 30 min delay message. How can I change it so the 30 min delay text is sent in 30 minutes ?
automations don’t handle notifications after a set time and there is no way to have it send the user for the lock
so 2 options to check out…
webcore:
LUM:
faq page:
Thanks I thought I was notified when a user used their code.
Any idea why I am getting so many alerts when the door is locked/unlocked
smart lock guest access is sending them
I would appreciate your help to get these 3 conditions on my app/smartthings hub
  1. When the schlage connect lock is UNlocked – I am sent a sms text message
  2. When the schlage connect lock is Locked – I am sent a sms text message
  3. When the schlage connect lock is left UNlocked for 30 minutes, the door is locked & I am sent a sms text message
Currently what I have isn’t “clean” for instance when I lock the lock, I get a lock message & and unlock sms text – please see the attached
Thank you !
Regards - Doug Cohen 310.261.5111
