Hello,
I have notifications when garage is left open for 30 minutes.
I have switches turned off with power allowance after x minutes
How do I get notification if light left on? Switches are not listed in shm.
Hello,
I don’t believe you can get any notifications running locally (Except for the security ones from the ADT model hub), because they all go through the cloud.
There are automations that can run locally, but only the ones in the official smart lighting feature and then some of the smart home monitor.
You can get a notification if the light is left on With webcore, but neither the automation nor the notification will run locally.
As always thanks, forget local, is there a built in way, seems odd that there is notification for open but not light on.
Will be setting up webcore I guess
