I have a smart things hub with the below specifications. I have a Candeo Led controller for zigbee. the controller is discovered, paired and connects fine to the hub and I can see it on the smart things app, but as soon as it’s connected, if I try to turn it on and off or change color via the app it does not work; the app reports a network error and after a few minutes the device is displayed as offline. the same thing happened with a gledopto 5-in-1 zigbee controller, which I returned thinking it was a faulty controller.
there are no obstructions in the way, the controller is very close to the hub (less than 3 feet). I have zigbee smart plugs that are much further away and they work perfectly fine.
- the controller is not faulty and it powers up a led strip just fine.
- I already try to reboot the hub and to disconnect it for 20 minutes while the zigbee controller is on.
- I always tried assigning a different driver to the controller (this one: (EDGE Driver-Mc): Zigbee Light Multifunction Mc - #136 by Mariano_Colmenarejo
- I tried resetting the controller
- I tried changing the zigbee channel from 24 (the default) to 11.
Nothing I tried works. The behaviour is still the same. The controller is discovered and pairs fine but then it cannot be controlled and changing colours or intensity does not work.
Please any help is appreciated.
The hub specs:
Aeotec Smart H> ome Hub - UK version
Manufacturer Aeotec
Part Number GP-AEOHUBV3UK
Item model number GP-AEOHUBV3UK
Supports Zigbee 3.0, Z-Wave, WiFi
Power Supply: 5V, 2A power adapter (Type G plug)
Regions: UK (Type G plug)
Z-Wave Frequency: 868,4 MHz (EU)
Certifications: Zigbee, Z-Wave, WWA, WWGA, FCC/IC/CE
The controller specs:
Connectivity Protocol ZigBee
Wattage 480 watts
Controller Type Remote Control, app control,control, Voice Control
Switch Type Dimmer Switch
Terminal Spade
Operation Mode automatic
Manufacturer : Candeo Smart Ltd
ASIN : B0D4Z1Q5MW
Item model number : C-ZB-LC20
Also tried, with the same exact results:
GLEDOPTO 5 in 1 ZIGBEE Mini RGB CCT RGBW Dimmer LED Controller DC5-24V IP20 Gateway APP Voice RF Remote Control
