If I write a piston URL to an NFC tag and scan it. My phone prompts me to open the URL in safari.
If I create a automation in the shortcuts app, works perfectly and doesn’t open up a browser as long as the URL is set to GET. BUT that automation has to be setup on each phone as they aren’t able to be shared
If I setup a routine in the shortcuts section. I can share it. But don’t have the ability to trigger via NFC.
Basically, I’m looking for a way to incorporate NFC, and have it where anyone in the house can use them, including guest, without having to setup the shortcuts/routines on everyone’s phone or have a browser open or require additional user input/actions.
Just scan the tag, done. No browser needing to open or confirmation needed to run.
I’m fairly new to the NFC tag thing, but regardless I feel like it should be easily accomplished. Anyone have any insight? Is it even possible?
