Newbie Forum search
How might I search the forum for a specific post # ?
I have the STv3 and searching for info on the Z-Wave Tweaker and every post I find about it mentions the post is obsolete and says to look at Post# 209 for the new version for the V3 hub.
I can’t seem to find a way to search by post#, nor stumble on that post.
The tweaker is obsolete, like all custom groovy DTHs.
The replacement that works with the new smartthings architecture is another community-created product, an edge Driver from @Mariano_Colmenarejo used for zwave configuration.
The fastest way to find that and other custom drivers is to use the quick Browse lists in the community – created wiki. In this case, it’s on the miscellaneous list.
https://thingsthataresmart.wiki/index.php?title=Quick_Browse_Lists_for_Edge_Drivers
In this case, I’ll save you a step. Here’s the direct link:
(EDGE Driver-Mc): Z-Wave Device Config Mc
If you don’t know what edge drivers are, or how to install them, see the community FAQ:
FAQ: I have no idea what Edge is. Is that a new developer tool? (2022)
As far as the question you specifically asked, when you are in a thread, the posts in that particular thread are numbered, and you should be able to see the numbers down the side of the page. In this screenshot, you can see that the first post is post 1 of 245 in the thread. you would’ve just scrolled down in that thread to get to post 209 in that thread. However, that post also linked to groovy DTH code which is now obsolete, so it wouldn’t have helped you anyway. You need something for the new architecture, which is the configurator tool I mentioned above.
Great! Thanks.
