Newbee, Having issue turning light on using motion sensor
Smart home monitor arm states are different than the modes. This is an area where many people get confused. So “armed away” is not the same thing as “away” when it comes to setting up a rule.
To set up something based on smart home monitor armed state, you can only use the smart home monitor feature.
When you are using smart lighting, you are setting it up based on the mode, not the armed state.
The following thread should help:
