Hi, I’m an Iris convert just getting situated with ST. I’m pretty much done getting all my devices switched over.
In going through these forums I now understand the frustration with the apps. I’m still learning a lot there.
I’m now working on schedules for my lights. In Iris, I could easily set on/off times. I’m finding it quite cumbersome with ST. Am I missing something? I hope I am. I’m using the routines from the classic app to set my on/off times.
Welcome! The official rules engine in the new app is somewhat easier to use and has more options than one in the classic app, so that’s something else to consider. You can use both apps at the same time if there are features that you want in both.
Otherwise, as @jkp Mentioned, start with the official “smart lights” feature in either of the two apps and see if you can do what you want there first. That’s the option that will run local, it’s newer than routines in the classic app, and it’s really the one that smartthings intends you to go to first even for many devices other than lights.
You might also find the following FAQ of interest (the topic title is a clickable link)
