I run into this
https://www.proshop.se/Smarta-Hem/Nedis-WiFi-Smart-Plug-with-Energy-Monitoring/2798473
Anyone who knows anything about this brand? Compatible with Smartthings?
I run into this
Not compatible
i’m looking also for how to connect nedis wifi led lamp to smartthings
https://webshop.nedis.nl/nl-nl/smart-living/smart-home/verlichting/550691222/wifilf10wta60
Looks like it is controlled through the Smart Life app, correct? You can either wait for the Globe Suite integration to return and try using that, or create a virtual switch in ST and use IFTTT as a man in the middle to toggle the bulb through the Smart Life app. This will at least give you on and off capability.
