Netatmo Connection In Limbo
Hello. I had attempted to connect with my Netatmo station. It did not find any devices to add and now I can not try again, nor delete the connection. I see no devices (obviously) in My Things, all I see is failure messages in the Live Logs. I went to go and connect again but I get a microscopic HTML type error message.
How do I purge the connection or correct the errors??
Support@smartthings.com
Or go into the IDE and try to delete there.
Thanks Brian. But the only thing I can find is an entry under “Installed Smart Apps” from under my home location. It does not, as far as I can tell, give me a way to delete it. There’s only an update button which did not work.
Click edit at the very top.
Bingo!! Thanks so much!!
