witch one and why ?
wich would be the best to use with smarttings
I am awaiting the Fibaro Smoke detector integration which would be my ideal choice based on size, looks and features.
Any online store i cna buy it from?? i cant find it on amazon, how much you paid for it?? looks awesome
I think it currently is only in Europe, but it shouldnât be too far away as Fibaro released most of their other new items in North America recently.
Nest integration with SmartThings is likely to remain uncertain for a while. Nest may consider themselves âcompetitorsâ to ST, unlike other less prominent brands.
My biggest concern is cost, though. Ideally, smoke detectors should be in every room that has a closed door⌠And more. Early detection is the key to survival and resolution.
So any reliable detector is best if affordable for maximum placements. ST integration may not be the highest priority if they provide a good alternative connection⌠I donât require âeverythingâ to be in the ST Cloud or App just yet, noting that ST has persisting reliability concerns for now too.
There is a Kickstarter or IndieGogo for a smart connected battery that you can insert into the existing detectors. Great idea if they deliver!
I really wish there was a zwave (or zigbee) detector that could be wired. I do not want to revert back to battery when I already have 8 wired detectors. I do have a relay hooked up, as per the thread below. But it would be great to have room level information for smoke detectors, just like the Nest Protects. I actually like the Nests a lot due to their functionality, but I do not like how much they have locked down their ecosystem. Yes, they have some IFTTT, but they have not really wanted to move beyond thatâŚwhich stinks. Time for someone to step in and fill that void.
Theyâve released barely any of their items in the US and I doubt the smoke detector will be here anytime soon. If they are having trouble getting their relay based modules UL certified over the last 8 months, I canât imagine they are going to have any luck with the much more stringent requirements for smoke detectors.
Nice post, Iâve been looking at those Roost battery widgets too. Iâm doing an addition which required hardwired interconnected smoke detectors which left my z-wave / zigbee options at 0, the nest satisfied those but A theyâre really expensive and B I wouldnât want to spend all that money and have spotty integration.
Iâm currently planning on trying the relay option⌠carefullyâŚ
The relay option works well. The issue, I have seen, is that modifying the device type to show up as a smoke detector and properly signal is an issue. Iâm guessing someone (not me, unfortunately) could modify it so that the contact sensor communicated like a smoke detector. Essentially, they are the same thing (when looking at a simple smoke detector)âŚthey are both boolean on/open or off/closed. So, it seems as though it would just be a matter of making the device type talk like a smoke detector.
Hmm⌠I was looking at IFTTT and I see that Nest Protect is there and it can pass the specific device. It seems as though you could do the following Rube Goldberg solution if you wantedâŚ
- Protect sends a trigger to IFTTT
- IFTTT sends a trigger to turn on the equivalent virtual switch in ST
- have ST react accordingly to that switch
The one issue I see immediately is the Next Protect trigger list does not include a condition cleared option. So, you need a way to turn that switch back off - perhaps with another smart app timer.
Seems convoluted with too many points of failure, but it looks as though it could be done.
Yea I think I found one a while ago:
Any Ideas? I hate having yet another extension cord in my basement.
Actually, I already have a wired interconnected smoke alarm ânetworkâ already in place. All Iâd need to have something hook into to the âinterconnectedâ portion of the system and tell ST about alerts starting and stopping. Is that what you guys are referring to with the ârelayâ method? Thanks.
YepâŚlook at the link a few posts up.
The V2 hub is supposed to support Thread. This is the protocol that the Nest Protect is using to communicate, hopefully it becomes a supported device.
Iâm interested to see what the First Alert smoke sensor can do. Iâd trust them more than some new brand with a safety device like a smoke alarm.
did you find any more info on this? doesnât look like it works with smartthings but it sure could
The âoldâ First Alert Z-Wave models work fine with SmartThings. At under $50, it is much more affordable to cover every room in my home.
Theyâve switched to a new protocol for these fancy linked models, and like all stovepipe technology, it will take a while for integrations to be built. The pressure for âWorks With SmartThingsâ has to be 3-fold⌠It has to come from Customers, SmartThings, and First Alert.
Thank you - I would have gone for the z wave first alerts but as iâm in Oz - i canât use US z wave freq.
Question for you about the âolderâ First Alert Z-wave smoke alarm: Can you silence the alarm from the ST app? Iâm looking at this one on Amazon.
I donât think so.
It is worth digging into the Z-Wave technical specs more closely to confirm, but I believe this is basically a âSensorâ, and thus, read-only (unlike a Lock, for example, that reports locked/unlocked and also accepts those Commands).
