First - thank you @dianoga for the Nest Device! I was able to get it setup and it appears functional as a device.
However, when I go to add an App (e.g. “Thermostat Window Check” by @imbrianj or the default “Keep Me Cozy” app) I’m not able to select one of my Nest tstats as a Thermostat.
Is there anything else I need to do to get them to show up?
OK, I created a new device type and made sure to select the Thermostat capability. If I save it with the generated code and go to the “My Device Types” view, it displays the capability.
However, when I copy your code from GitHub and paste it in, save, and publish it, the capability gets dropped. I tried it a couple times and noticed the same behavior each time. Am i doing something wrong here?
You would need to add the appropriate capabilities. Also, it’s presence isn’t done to match the presence capability. That will be fixed when I build using the official api.
