Nest Integration - Using "dianoga", author: "Brian Steere" Template
Hi
I can’t seem to get this up and running, I install the Nest Thermostat template,
then i create a device, but can not find where to enter my Next credentials
V2 hub and latest iOS app
any assistance is appreciated
thanks!
    1. Create a new device (https://graph.api.smartthings.com/device/list)
  • Name: Your Choice
  • Device Network Id: Your Choice
  • Type: Nest (should be the last option)
  • Hub/Group: Leave blank
  • 4) Update device preferences
  • **Click on the new device to see the details.**
  • **Click the edit button next to Preferences**
  • **Fill in your information.**
  • **To find your serial number, login to http://home.nest.com. Click on the thermostat**
  • **you want to control. Under settings, go to Technical Info. Your serial number is**
  • **the second item.**
    1. That’s it, you’re done.
UPDATE - GOT IT
thanks all.
I don’t get an area that has preferences where I can enter in my nest credentials
I know this should be easy but not happening for me
What step am I missing ?
i also dont see preferences? any one who has encountered this problem?
You don’t see the triple dots in the upper right hand corner of the device in the ST app?
i do, but when i click them, i dont see preferences as an option
