Not yet, although I could possibly add that. The new version does support you using your own media file and adds a “STOP” command, so you could handle it that way.
little help wanted, i have set to announce when someone leaves and arrives, how ever, smartthings has told me i have left yet i have not?
If it’s Android, you could try looking here…
Of course, there are probably other threads about it too, but since that one is fresh on my mind from dealing with the same thing, I figured I’d share it.
Hi I’m currently using LANnouncer with WebCore, and on my new Fire 8 Speech Syntesis doesn’t work, while chimes and alarm work.
On my older Fire everything work (the same piston make the Fire 7 speak, while the Fire 8 doesn’t).
How could I fix this?
Looking for a little help here. I recently installed LANnouncer on my Android (Samsung Galaxy S9+) and I can get it to work once, but then I have to STOP the Service and Start the Service if I want it to work again. Even back to back tries!
My trigger is SHM Alarm Delay and BigTalker 2.
A little more detail would be helpful. Did you try the troubleshooting section of the online manual? It walks you through testing it with your own web browser.
Sorry it took do long to respond. I’ve been trying simple things to learn something new and I can’t seem to keep it running. I have Lannouncer running on my Android phone. I have a very simple piston that says when button is pressed, say Hello World! When I start the Lannouncer service it works great but then after a few tries it stops working. If I keep using it repeatably it keeps working, but if I leave it for a few seconds (15), it stops responding. I have to stop the service and restart it in order for it to work again. Ip addresses are correct. No other changes. It must be an OS issues or setting in my phone that creates the issue?
Just wondering if this thread is dead or not. I would really like to have this Lannouncer to be finetuned for my needs.
Yeah, it’s dead. After the support woes here, I moved to Hubitat.
But I’m listening. What would you like?
