Hello,
I’m looking for something that just might not be possible. I have a GE paddle switch that turns on 5 recessed lights. The recessed lights have all the fun features such as rgbw, dimming, and white light control. Currently a virtual switch turns these on and off and controls a lot of the features. This is done through webcore
Webcore programming in a nut shell: If virtual switch changes color then recessed lights change color. Etc.
What I’d like to do is have my ge switch have a custom device handler that allows me to still do the the on/off double tap feature and has virtual settings for dim, 2700-6500 scale, and rgbw. This could eliminate my virtual switch leaving me with one switch.
I’ve messed around with the following device handlers to see if I can combine them but I havent had any luck.
nuttytree/Nutty-SmartThings/blob/master/devicetypes/nuttytree/ge-jasco-zwave-plus-on-off-switch.src/ge-jasco-zwave-plus-on-off-switch.groovy
sticks18/Fibaro-RGBW-Group-Controller/blob/master/Virtual_Fibaro_RGBW_Device.groovy (had to change the white level to 2700-6500 scale)
I’ve also just added the generic rgbw device handler in smartthings to the ge switch and the on and off work. When I test the rest with webcore code the color changing, dimming, etc all work. All I’m missing is the double tap feature. Is there a way to to this? Or has someone already done this?
