I’m not an IT guy or a programmer so I’m hoping someone can help me out here.
Looking for the simplest way to have a switch turn on for a few minutes and off every hour of the day, every day of the week.
I have to recommend webCoRE to manage this complex automation
Webcore would certainly do it, but you could also just do it with a daisy chain to a virtual timer. All you need is smartlighting.
Switch A turns on and you use power allowance to have it turn itself off after, say, three minutes.
Then have a virtual switch which turns itself on when the physical switch turns itself off. Use power allowance to have The virtual switch turn itself off after 57 minutes.
Then have a third automation so that switch A turns itself on when the virtual switch turns itself off.
The result is an infinite loop which triggers Switch A every 60 minutes.
Note however that there is no way to stop this without disabling one of the automations.
How does the power allowance portion work? Does the plug you are using have to have a power monitoring feature?
