Hi,
I’m trying to integrate a Nedis Zigbee Motion Sensor into Smartthings.
It is not officially supported - have anyone made a device handler or do you know any other work-around?
Thank you in advance.
Hi,
Try joining it to the hub via the Scan Nearby option. When/If it joins, it will probably join as a Thing. Change the device Type field to “SmartSense Motion Sensor” and see if that works for it.
Thank you very much!
Thank did the trick!
is this sensor any good?
I think I’ll call it mediocre. It’s a bit slow, but it works. And it’s cheap.
Hi. For everyone else having problems with this device I was able to get it working correctly with Zigbee Motion Sensor Mc edge driver: GitHub - Mariano-Github/Edge-Drivers-Beta: Edge Driver Beta Modified for Created
Changing the device type didn’t work for me.
