Hi everyone. As you may have read in my posts over the last few weeks, I very recently fired up my SmartThings hub again after taking a break for awhile and playing with other platforms.
A big part of this, for me, is that I have slowly been pushing my home towards Matter, as much as possible. If I already have a ton of stuff connecting over Matter, why not connect them to ST as well? It can only open more possibilities!
But what I didn’t anticipate was after making the Matter connections with my V3 hub, along with adding the associated drivers, I was already pushing the device limits for said hub. And that was before adding the small zwave and zigbee networks I had been planning on incorporating in to ST.
After doing some research, I decided on a plan. Add a ST Station to a hub group. The V3 hub would handle the Matter and zwave network (around 20ish devices) and corresponding drivers. The Station would handle the zigbee network (40-50 devices) along with any Thread items I end up adding (not planned at the moment, but you never know) and their corresponding drivers.
Two issues I discovered: for a zwave network to work, the hub that controls zwave must be the primary hub AND when attempting to pair a zigbee device, it will add to whichever is considered the primary hub. Meaning in a hub group environment, I could not use the Station as the zigbee controller.
So I turned off the hub group and separated them. This way I can choose which hub each device I want to add will go to, this achieving the goal I stated above.
Does this make the most sense? Or does the hub group manage this automatically? I guess what I’m saying is does the hub group increase the device limit so that when the primary gets filled up, devices added to the account automatically get added to the secondary hub? Or is the answer door #3 - I’m way off base and approaching this all wrong?
Additionally, I’m trying to be conscious of zigbee interference, both with other zigbee networks (hue, aqara, ikea…don’t ask) and with wifi. So if I am not intending to use the zigbee or thread radios in the V3 hub, could they be disabled so they aren’t sitting out there on a channel but not doing anything? I am more than likely going to change the zigbee channel the Station is using since it is the same as the Ikea hub and that one can’t be changed, to my knowledge. Do I need to change the V3 accordingly if I can’t turn it off?
Also if zigbee channels 11, 15, 20, and 25 are all in use
…what does that mean for wifi?
Oh and is there still a master list of drivers somewhere? I seem to recall a wiki link at some point but I can’t find it now. I’m particularly interested in those provided directly by the manufacturers, like Zooz and Third Reality have done.
