Hey everyone.
Is it possible to have a door lock when a multi sensor is closed? I saw a post about it but it was almost 6 months old.
Right now my front door unlocks when I arrive home but I want it to lock automatically when I shut the door.
Hey everyone.
Hi Steve,
There is an app somebody shared in the IDE SmartApps section that can lock a door after n minutes. I modified it to be aware of a contact sensor attached to the same door. The lock will not lock if the door is open. If somebody locks it while open, it will automatically unlock it.
I’m not a developer, but here is the modified code:
* Auto Lock Door v2
* Added: Door contact sensor awareness
* Modified by: alegreg@verizon.net
* Original Author: Chris Sader (@csader)
* Collaborators: @chrisb
* Date: 03/23/2014
* Copyright (C) 2013 Chris Sader.
* Permission is hereby granted, free of charge, to any person obtaining a copy of this
* software and associated documentation files (the "Software"), to deal in the Software
* without restriction, including without limitation the rights to use, copy, modify,
* merge, publish, distribute, sublicense, and/or sell copies of the Software, and to
* permit persons to whom the Software is furnished to do so, subject to the following
* conditions: The above copyright notice and this permission notice shall be included
* in all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED,
* INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
* PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
* HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF
* CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE
* OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
preferences
section("Select the door lock:") {
input "lock1", "capability.lock", required: true
section("Select the door contact sensor:") {
input "contact", "capability.contactSensor", required: true
section("Automatically lock the door...") {
input "minutesLater", "number", title: "Delay (in minutes - default is 5):", required: false
section("Unlock it if the lock is manually engaged while the door is open...") {
input "minutesLater2", "number", title: "Delay (in minutes - default is 1):", required: false
def installed()
log.debug "Auto Lock Door installed."
initialize()
def updated()
unsubscribe()
unschedule()
log.debug "Auto Lock Door updated."
initialize()
def initialize()
log.debug "Settings: ${settings}"
subscribe(lock1, "lock", doorHandler, [filterEvents: false])
subscribe(lock1, "unlock", doorHandler, [filterEvents: false])
subscribe(contact, "contact.open", doorHandler, [filterEvents: false])
subscribe(contact, "contact.closed", doorHandler, [filterEvents: false])
def lockDoor()
log.debug "Locking the door."
lock1.lock()
def unlockDoor()
log.debug "Unlocking the door."
lock1.unlock()
def doorHandler(evt)
log.debug "Event: The ${evt.name} is ${evt.value}."
log.debug "Contact value: The contact is ${contact.latestValue("contact")}."
log.debug "Lock value: The lock is ${lock1.latestValue("lock")}."
if ((contact.latestValue("contact") == "open") && (evt.value == "locked")) { // If the door is open and a person locks the door then...
def delay = minutesLater2 * 60 ?: 60 // runIn uses seconds
log.debug "Door is open and somebody just locked it. Unlocking the door!"
runIn( delay, unlockDoor ) // ...schedule (in minutes) to unlock... We don't want the door to be closed while the lock is engaged.
else if ((contact.latestValue("contact") == "open") && evt.value == "unlocked") { // If the door is open and a person unlocks it then...
log.debug "Cancel the current task. Door is open and somebody just unlocked it!"
unschedule( unlockDoor ) // ...we don't need to unlock it later.
else if ((contact.latestValue("contact") == "closed") && (evt.value == "locked")) { // If the door is closed and a person manually locks it then...
log.debug "Cancel the current task. Door is closed and somebody just locked it!"
unschedule( lockDoor ) // ...we don't need to lock it later.
else if ((contact.latestValue("contact") == "closed") && (evt.value == "unlocked")) { // If the door is closed and a person unlocks it then...
log.debug "Door is closed and somebody just unlocked it. Locking the door!"
def delay = minutesLater * 60?: 300 // runIn uses seconds
log.debug "Re-arming lock in ${minutesLater} minutes (${delay}s)."
runIn( delay, lockDoor ) // ...schedule (in minutes) to lock.
else if ((lock1.latestValue("lock") == "unlocked") && (evt.value == "open")) { // If a person opens an unlocked door...
log.debug "Cancel the current task. Door is unlocked and somebody just opened it!"
else if ((lock1.latestValue("lock") == "unlocked") && (evt.value == "closed")) { // If a person closes an unlocked door...
log.debug "Door is unlocked and somebody just closed it. Locking the door!"
else {
log.debug "Ohh.. no!!.. The lock is jammed!! or worst.. The door was probably forced open or close!!!"
I’m slowly learning how to code (mainly by looking at the SmartApp examples). I love the IDE simulator and the debug/logs console.
This looks great. I will give it a try. Thank you for posting the modified code. I plan to start trying some coding myself at some point.
