WB70
January 11, 2018, 5:06am
11
adrianyoung:
I have core and webcore installed now.
I need to raise a ticket for the actual issue. When the LIFX lights are set <10%, SmartThings won’t turn them on. The native LIFX app will. As they are set to come on automatic with motion detection, I have to keep them
If you follow these instructions you don’t need to set your lights with SmartThings. You can set your lights exactly the way you have them defined in scenes directly in your LIFX app which will set the bulb brightness and color for all your bulbs:
Prerequisites:
Have webCoRE installed
Own at least one Hue bulb -or-
Own at least one LIFX bulb
Have at least one Scene defined in your Hue or LIFX Mobile App
Summary:
This is for those of you who would like to be able to set a predefined scene that you previously created in Hue and/or LIFX from within SmartThings via webCoRE Piston.
This eliminates in most cases, the need for you to have to create a “Scene” using the SmartThings App and then having to create a SmartThings Routine to set that scene, allowing you to reuse one set of predefined scenes directly from Hue or LIFX.
Instructions:
Hue:
In IFTTT, connect to the Webhooks service.
Take the url created for your connection (Use a laptop or non phone device - Makes it easier for copying and pasting)
Open webCore Dashboard / Set…
Open that thread and take a look. This could solve some of your issues with ST not being able to do it correctly.
