I have discovered a bug where if you refresh the motion sensor in the Smartthings app too many times, the device registers that as a motion.
This is bad because I have connected my motion sensors to my Smart home monitor. When I am away from home the system uses those to detect intruders, yet by refreshing one too many times it will trigger a fake motion and the alarm will go off.
Below are my steps to reproduce.
using a SmartThings Hub, a Smartthings motion sensor and the iOS Smartthings app
choose your motion sensor in the app
you should be taken to a detailed view where you can pull toff refresh or tap the button to refresh.
pull to refresh
tap the refresh button
repeat 3 & 4 a few times (at least 5 times)
Expected no motion to be detected
Actual: motion is detected even though there wasn’t one.
Can anyone else reproduce this and where can I report the bug?
I originally had two Smartthings motion sensors. One a couple of feet from the SmartThings Hub and one at the end of its reach. I assumed it is at the end because it would frequently go offline.
Both motion sensors exhibited the bug.
To prevent the far one from disconnecting I got a Smartthings outlet to make use of its repeater functionality.
I retested the bug but was unable to reproduce it in the far away one but still able to reproduce it in the near one.
The near one probably does not use/need the repeater. But the far one probably does.
