currently onsale for $17.50 but use coupon code AUG10 to bring the price down to $15.75. I just ordered 5
3 of the 5 reviews on monoprice say it doesnât work with smartthings. Anyone know differently? Was about to pick two up until i read that.
Yeah, that bit seems kind of important.
If itâs z-wave, it certainly should be possible to write a custom device for it.
oh crap⌠forgot to check ST compatibility
device type anyone?
I bought one yesterday. I saw that there wasnât a device type for them, but Iâve wanted to learn how that works so I figured this would give me a reason to learn.
If anyone else gets this deal and is planning on working on a device type, let me know if you would like to work together on the code.
Anyone created a device type for this yet? I am trying but not having luck. I found the programming manual for it here https://fccid.io/document.php?id=2040683 but iâm clueless with the zwave command class stuffs.
No matter what i am doing to this device, all i see it sending is
debug Parsed AlarmReport(alarmLevel: 255, alarmType: 1) to [ânameâ:âsmokeâ, âvalueâ:âsmokeâ, âdescriptionTextâ:DownStair Smoke Detector smoke is detected, âisStateChangeâ:false, âdisplayedâ:false, âlinkTextâ:âDownStair Smoke Detectorâ]
debug Parsed AlarmReport(alarmLevel: 255, alarmType: 1) to [ânameâ:âsmokeâ, âvalueâ:âsmokeâ, âdescriptionTextâ:DownStair Smoke Detector smoke is detected, âisStateChangeâ:true, âdisplayedâ:true, âlinkTextâ:âDownStair Smoke Detectorâ]
According to the little pamplet that comes with it, a tamper alarm is suppose to send (alarm type 02 and alarm level 255) BUT all it send is (alarmLevel: 255, alarmType: 1)
Any help would be awesomeâŚ
hi,
Did you get your smoke detector from monoprice yet? Any luck getting the device type to work yet? I started one and got some basic functions to work. It will detect smoke and send an alert to ST. I tested it by burning incense under the sensor. I canât seem to get the tamper alarm to send the alert. The device send the same thing as a fire detected. I contacted Monoprice to see if they have better documentation on which zwave command class this thing support but no luck. There seems to be a few manufacturers out there with the exact same thing but their documentation are all different.
So far, I see Everspring, Zipato, vision⌠some are zwave plus. I am guessing this is not a zwave plus device.
The Monoprice looks the same as the Everspring SF813:
I got mine on Friday but havenât had time to play with it until today. Do you have a github for your current code?
Just loaded it to github.
Neat, thanks. Iâve forked your repo and will do a pull request with any updates. Iâll be playing with it a little today but probably will get more work done on it during the week.
So I ended up getting sucked into writing a device type for this today. It was a lot of fun! I now understand device types much better now.
Anyways, my completed device type can be found here:
These are onsale again at monoprice for $15 plus free shipping.
