Monoprice Dual Relay
I have a two Moniprice Dual Relays installed at least 3 years ago. I used the justintime code. For some reason when I turned the main power off, the relays stopped working. The app shows the device as turning off/on but the device (light bulb) doesn’t actually turn on.
I’m sure there is a solution, I just couldn’t find it on search. Thanks
If the mains are turned off, won’t the relays not have any power to operate?
They were turned back on in a few minutes. Everything else was working fine except for the relays.
Can you control it manually?
Yes I can. I also see the virtual switch turn on and off.
Did you connect to the neutral? I know it’s a basic question…
I can turn the switch on/off manually so the bulbs are fine. I will double check on the clicking when I get home.
Nope. Can’t control in ST. I can’t hear the audible clicks either that I used to. So it’s something with the relay module. First step would be to remove it and the virtual switches and reinstall.
Now, if I can only remember how to as it was 3 years ago :smile:
Sorry to get a bit off topic but you screen shot shows power monitoring. Is that for the monoprice module? I would love to have that.
