MOES ZigBee thermostat drivers
Hello, I buy Star Ring Moes ZigBee thermostat and want to add it to ST. Anyone know about drivers that can work for it. ST shows as ZigBee thing on MC drivers and beta drivers:
On Yakov drivers:
Regards.
You could try the Zigbee Thermostat Mc or Zigbee Temp Sensor and Child Thermostat Mc from @Mariano_Colmenarejo by subscribing to his channel here and installing the driver. If neither of those work, you can install his Zigbee Thing driver to get all the information about the device and post in this topic.
Hi,
You can try with this driver thermostat and if not works then, ask to @otivax if can add your thermostat fingerprints to driver
Hi, I install ‘Zigbee Temp Sensor with Thermostat Mc’, ‘Zigbee Temp Sensor and Child Thermostat Mc’ and ‘Zigbee Thermostat Mc’ but I cannot choose them for that device.
If you have the driver installed, try remove device and add device again
Hi, I try that. I will stick with Tuya app for now. I need to fix and calibrate that device to work.
I have managed to get this star thermostat working with an edge driver I have been working on in my channel if anyone would like to try it. I have only got basic functionality tested but the main thing is you can set the temperature from your phone. SmartThings. Add a little smartness to your things.
For reference it’s info below
deviceLabel: "Moes Star Ring Thermostat"
manufacturer: "_TZE204_lpedvtvr"
model: "TS0601"
deviceProfileName: moes-thermostat
