As of last night, my Aeon minimotes will no longer toggle devices on/off when used with Smart Lighting. They will turn the device on or off (seems to vary by device) but won’t reverse the state no matter how many times I push it.
I have the same problem with minimote and lights. The first button push works for any button, then subsequent ones do nothing. If I wait a while, another button will work, but the previous one, or any other do not work. I have not run the experiment on how long to wait but it is definitely many minutes.
I noticed this started last night 7/21. Affects all my minimotes (5).
Summary: first button pushed of any of the 4 work. Subsequent buttons pushed, or the same one, do not. Wait TBD, the first button of any of the 4 pushed, which can be a different one, works just one time.
hub firmware version: 000.022.00013
hardware: hub v2, US customer Rev E
I am having the same problem starting at the same time. I have tried excluding the remote and adding it back as well as reprogramming the buttons. Nothing I have tried has worked. Definately a new bug.
For those of you experiencing the issue, are the Smart Lighting rules that aren’t consistently working running in the cloud or locally? My locally running rules seem to work fine but the cloud ones are not.
I think I have at least one that should be running local that is failing. A Minimote controlling a Z-Wave socket via Smart Lighting should be local, right?
It depends on how it’s set up. You can double check where things run by going to your Location in graph, then click List SmartApps and look for the Smart Lighting section.
To get it to run locally try going into the Smart Lighting rule and change the Which Button to the minimote device itself, not a specific button. Then select the appropriate button under Button number. Click Next and Save and it should switch to running locally. This should get around the issue while we get it fixed although it’s fine to leave it like that permanently.
Just replying to say I’m seeing it here too. Grrr… Is there an easy way to get these to run locally? Not sure what you’re talking about when you refer to smart lighting. When I go to button controller and program individual buttons, it still runs in the cloud. Time to go to Hubitat?
