Matter device pairing issue with Smartthings app on iPhone (April 2025)
Hello everyone,
We are currently working on Matter product integration with the SmartThings app. However, we’ve encountered a strange issue: when adding the Matter device using the SmartThings app on an iPhone, the process fails right after the message saying the device will first be added to iCloud. In contrast, adding the same device using the SmartThings app on an Android phone works successfully.
Below are the logs for the failed attempt on iPhone
I: 3085619 [DL]Current number of connections: 1/1
I: 3085624 [DL]BLE connection established (ConnId: 0x00)
I: 3085629 [DL]CHIPoBLE advertising stopped
I: 3085633 [DL]NFC Tag emulation stopped
D: 3086405 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3086413 [BLE]local and remote recv window sizes = 5
I: 3086417 [BLE]selected BTP version 4
I: 3086421 [BLE]using BTP fragment sizes rx 182 / tx 182.
D: 3086525 [DL]ConnId: 0x00, New CCCD value: 0x0002
D: 3086530 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 6)
D: 3086538 [IN]BLE EndPoint 0x20011be8 Connection Complete
I: 3086543 [DL]CHIPoBLE connection established (ConnId: 0x00, GATT MTU: 185)
D: 3086585 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3086594 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3086602 [EM]>>> [E:38188r S:0 M:242455604] (U) Msg RX from 0:AEFD1102A8AFF0D3 [0000] to 0000000000000000 --- Type 0000:20 (SecureChannel:PBKDFParamRequest) (B:98)
I: 3086617 [EM]<<< [E:38188r S:0 M:131729297] (U) Msg TX from 0000000000000000 to 0:AEFD1102A8AFF0D3 [0000] [BLE] --- Type 0000:21 (SecureChannel:PBKDFParamResponse) (B:154)
D: 3086632 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 159)
I: 3086640 [SVR]Commissioning session establishment step started
D: 3086765 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3086774 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3086782 [EM]>>> [E:38188r S:0 M:242455605] (U) Msg RX from 0:AEFD1102A8AFF0D3 [0000] to 0000000000000000 --- Type 0000:22 (SecureChannel:PASE_Pake1) (B:92)
I: 3086821 [EM]<<< [E:38188r S:0 M:131729298] (U) Msg TX from 0000000000000000 to 0:AEFD1102A8AFF0D3 [0000] [BLE] --- Type 0000:23 (SecureChannel:PASE_Pake2) (B:127)
D: 3086836 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 132)
D: 3086885 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3086894 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3086902 [EM]>>> [E:38188r S:0 M:242455606] (U) Msg RX from 0:AEFD1102A8AFF0D3 [0000] to 0000000000000000 --- Type 0000:24 (SecureChannel:PASE_Pake3) (B:59)
I: 3086916 [EM]<<< [E:38188r S:0 M:131729299] (U) Msg TX from 0000000000000000 to 0:AEFD1102A8AFF0D3 [0000] [BLE] --- Type 0000:40 (SecureChannel:StatusReport) (B:30)
D: 3086931 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 35)
I: 3086940 [SC]SecureSession[0x20004500, LSID:35051]: State change 'kEstablishing' --> 'kActive'
D: 3086948 [IN]SecureSession[0x20004500]: Activated - Type:1 LSID:35051
D: 3086954 [IN]New secure session activated for device <FFFFFFFB00000000, 0>, LSID:35051 PSID:63414!
I: 3086963 [SVR]Commissioning completed session establishment step
I: 3086969 [DIS]Updating services using commissioning mode 0
E: 3086975 [DIS]Failed to remove advertised services: 3
E: 3086980 [DIS]Failed to finalize service update: 3
D: 3086985 [DL]CHIPoBLE advertising set to off
I: 3086989 [SVR]Device completed Rendezvous process
D: 3087035 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3087044 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3087052 [EM]>>> [E:38189r S:35051 M:71336357] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3087065 [IM]Received Read request
I: 3087070 [EM]<<< [E:38189r S:35051 M:67378413] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:74)
D: 3087083 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 79)
D: 3087215 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3087224 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3087232 [EM]>>> [E:38190r S:35051 M:71336358] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3087245 [IM]Received Read request
I: 3087250 [EM]<<< [E:38190r S:35051 M:67378414] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:94)
D: 3087263 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 99)
D: 3087335 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3087344 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3087352 [EM]>>> [E:38191r S:35051 M:71336359] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:52)
D: 3087365 [IM]Received Read request
I: 3087369 [EM]<<< [E:38191r S:35051 M:67378415] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:67)
D: 3087383 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 72)
D: 3087455 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3087464 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3087472 [EM]>>> [E:38192r S:35051 M:71336360] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3087485 [IM]Received Read request
I: 3087490 [EM]<<< [E:38192r S:35051 M:67378416] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:66)
D: 3087503 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 3087575 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3087584 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3087592 [EM]>>> [E:38193r S:35051 M:71336361] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:59)
D: 3087607 [DL]OpenThread State Changed (Flags: 0x01009009)
D: 3087613 [DL]   Network Name: OpenThread
D: 3087617 [DL]   PAN Id: 0xB3DE
D: 3087620 [DL]   Extended PAN Id: 0xDEAD00BEEF00CAFE
D: 3087624 [DL]   Channel: 11
D: 3087627 [DL]   Mesh Prefix: fdde:ad00:beef::/64
D: 3087631 [DL]   Thread Unicast Addresses:
D: 3087636 [DL]        fe80::645d:b1e:4628:2488/64 valid preferred
D: 3090091 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 3090215 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
I: 3091693 [DL]Thread Network: ST-3011076154 Panid 0x6b67 Channel 24 RSSI -42 LQI 220 Version 4
I: 3092047 [DL]Thread Network: MyHome923430646 Panid 0xf4ec Channel 25 RSSI -68 LQI 108 Version 4
D: 3092492 [DL]OpenThread State Changed (Flags: 0x00008000)
D: 3092497 [DL]   Network Name: OpenThread
D: 3092501 [DL]   PAN Id: 0xFFFF
D: 3092504 [DL]   Extended PAN Id: 0xDEAD00BEEF00CAFE
D: 3092508 [DL]   Channel: 11
D: 3092511 [DL]   Mesh Prefix: fdde:ad00:beef::/64
I: 3092517 [EM]<<< [E:38193r S:35051 M:67378417] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:178)
D: 3092532 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 182)
D: 3092540 [DL]OpenThread State Changed (Flags: 0x01002002)
D: 3092545 [DL]   Thread Unicast Addresses:
D: 3092615 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3092676 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 3092859 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3092867 [EM]>>> [E:38194r S:35051 M:71336362] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:131)
D: 3092880 [IM]Received Read request
I: 3092887 [EM]<<< [E:38194r S:35051 M:67378418] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:258)
D: 3092901 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 182)
D: 3092975 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3092983 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 83)
D: 3093095 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3093105 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3093113 [EM]>>> [E:38195r S:35051 M:71336363] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:106)
D: 3093126 [IM]Received Read request
E: 3093130 [DMG]Fail to retrieve data, roll back and encode status on clusterId: 0x0000_0046, attributeId: 0x0000_0002err = 5c3
E: 3093142 [DMG]Fail to retrieve data, roll back and encode status on clusterId: 0x0000_0046, attributeId: 0x0000_0001err = 5c3
E: 3093153 [DMG]Fail to retrieve data, roll back and encode status on clusterId: 0x0000_0046, attributeId: 0x0000_0000err = 5c3
E: 3093164 [DMG]Fail to retrieve data, roll back and encode status on clusterId: 0x0000_0046, attributeId: 0x0000_0007err = 5c3
E: 3093175 [DMG]Fail to retrieve data, roll back and encode status on clusterId: 0x0000_0046, attributeId: 0x0000_0006err = 5c3
I: 3093187 [EM]<<< [E:38195r S:35051 M:67378419] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:180)
D: 3093201 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 182)
D: 3093275 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3093283 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 5)
D: 3093455 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3093464 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3093472 [EM]>>> [E:38196r S:35051 M:71336364] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:65)
I: 3093486 [FS]GeneralCommissioning: Received ArmFailSafe (60s)
I: 3093493 [EM]<<< [E:38196r S:35051 M:67378420] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:66)
D: 3093508 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 3093635 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3093644 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3093652 [EM]>>> [E:38197r S:35051 M:71336365] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:70)
I: 3093669 [EM]<<< [E:38197r S:35051 M:67378421] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:66)
D: 3093684 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 3093755 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3093764 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3093772 [EM]>>> [E:38198r S:35051 M:71336366] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:62)
I: 3093787 [ZCL]OpCreds: Certificate Chain request received for PAI
I: 3093793 [EM]<<< [E:38198r S:35051 M:67378422] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:527)
D: 3093808 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 182)
D: 3093936 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3093943 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 182)
D: 3094056 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3094063 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 172)
D: 3094295 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3094304 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3094312 [EM]>>> [E:38199r S:35051 M:71336367] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:62)
I: 3094327 [ZCL]OpCreds: Certificate Chain request received for DAC
I: 3094333 [EM]<<< [E:38199r S:35051 M:67378423] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:556)
D: 3094348 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 182)
D: 3094536 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3094543 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 182)
D: 3094656 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3094663 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 182)
D: 3094776 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3094783 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 21)
D: 3094895 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3094904 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 3095018 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3095026 [EM]>>> [E:38200r S:35051 M:71336368] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:94)
I: 3095040 [ZCL]OpCreds: Received an AttestationRequest command
I: 3095048 [ZCL]OpCreds: AttestationRequest successful.
I: 3095054 [EM]<<< [E:38200r S:35051 M:67378424] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:716)
D: 3095068 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 182)
D: 3095196 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3095203 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 182)
D: 3095376 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3095383 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 182)
D: 3095496 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3095503 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 181)
D: 3095615 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3095624 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 3095737 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3095745 [EM]>>> [E:38201r S:35051 M:71336369] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:65)
I: 3095759 [FS]GeneralCommissioning: Received ArmFailSafe (60s)
I: 3095766 [EM]<<< [E:38201r S:35051 M:67378425] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:66)
D: 3095781 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 3095856 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3097298 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3097306 [EM]>>> [E:38202r S:35051 M:71336370] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:94)
I: 3097320 [ZCL]OpCreds: Received a CSRRequest command
I: 3097331 [ZCL]OpCreds: AllocatePendingOperationalKey succeeded
I: 3097338 [ZCL]OpCreds: CSRRequest successful.
I: 3097343 [EM]<<< [E:38202r S:35051 M:67378426] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:392)
D: 3097358 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 182)
D: 3097536 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3097543 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 182)
D: 3097656 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3097663 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 37)
D: 3097776 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3097785 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 3097899 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3097907 [EM]>>> [E:38203r S:35051 M:71336371] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:316)
I: 3097922 [ZCL]OpCreds: Received an AddTrustedRootCertificate command
I: 3097930 [ZCL]OpCreds: AddTrustedRootCertificate successful.
I: 3097936 [EM]<<< [E:38203r S:35051 M:67378427] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:63)
D: 3097951 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 68)
D: 3098076 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3098085 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 3098200 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3098208 [EM]>>> [E:38204r S:35051 M:71336372] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:352)
I: 3098222 [ZCL]OpCreds: Received an AddNOC command
I: 3098228 [FP]Validating NOC chain
I: 3098234 [FP]NOC chain validation successful
I: 3098238 [FP]Added new fabric at index: 0x1
I: 3098242 [FP]Assigned compressed fabric ID: 0x5329CE4A2334A18B, node ID: 0x000000001EAD6F46
I: 3098251 [TS]Last Known Good Time: 2023-10-14T01:16:48
I: 3098256 [TS]New proposed Last Known Good Time: 2025-04-09T02:51:42
I: 3098262 [TS]Updating pending Last Known Good Time to 2025-04-09T02:51:42
I: 3098278 [ZCL]OpCreds: ACL entry created for Fabric index 0x1 CASE Admin Subject 0x0000000054FD3CBA
D: 3098287 [DL]Using Thread extended MAC for hostname.
I: 3098291 [DIS]Advertise operational node 5329CE4A2334A18B-000000001EAD6F46
E: 3098298 [SVR]Operational advertising failed: 3
I: 3098303 [ZCL]OpCreds: successfully created fabric index 0x1 via AddNOC
I: 3098310 [EM]<<< [E:38204r S:35051 M:67378428] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [A18B] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:66)
D: 3098325 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
E: 3098332 [DL]Long dispatch time: 132 ms, for event type 16388
D: 3098436 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3098445 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3098453 [EM]>>> [E:38205r S:35051 M:71336373] (S) Msg RX from 1:FFFFFFFB00000000 [A18B] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:135)
I: 3098470 [EM]<<< [E:38205r S:35051 M:67378429] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [A18B] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:66)
D: 3098485 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 3098556 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3098564 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3098572 [EM]>>> [E:38206r S:35051 M:71336374] (S) Msg RX from 1:FFFFFFFB00000000 [A18B] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:65)
I: 3098587 [FS]GeneralCommissioning: Received ArmFailSafe (94s)
I: 3098593 [EM]<<< [E:38206r S:35051 M:67378430] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [A18B] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:66)
D: 3098608 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 3098736 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3098745 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3098753 [EM]>>> [E:38207r S:35051 M:71336375] (S) Msg RX from 1:FFFFFFFB00000000 [A18B] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:73)
D: 3098799 [DL]OpenThread State Changed (Flags: 0x100fc100)
D: 3098804 [DL]   Network Name: ST-3011076154
D: 3098808 [DL]   PAN Id: 0x6B67
D: 3098811 [DL]   Extended PAN Id: 0x8B28D6D445476F03
D: 3098816 [DL]   Channel: 24
D: 3098818 [DL]   Mesh Prefix: fdde:ad00:beef::/64
D: 3098826 [DL]OpenThread State Changed (Flags: 0x1100100d)
D: 3098831 [DL]   Device Role: DETACHED
D: 3098835 [DL]   Thread Unicast Addresses:
D: 3098839 [DL]        fdde:ad00:beef:0:f7ba:38cf:b770:ad1f/64 valid preferred
D: 3098846 [DL]        fe80::645d:b1e:4628:2488/64 valid preferred
I: 3100096 [DL]SRP Client was started, detected server: fd6e:d157:02b4:cdbf:6864:fb66:d7b6:d6fc
I: 3100105 [ZCL]ThreadDiagnosticsDelegate: OnConnectionStatusChanged
D: 3100111 [DL]OpenThread State Changed (Flags: 0x301032b7)
D: 3100116 [DL]   Device Role: CHILD
D: 3100120 [DL]   Partition Id: 0x78624E99
D: 3100123 [DL]   Thread Unicast Addresses:
D: 3100127 [DL]        fd41:8102:3c8a:1:8842:8ece:3871:5cee/64 valid preferred
D: 3100134 [DL]        fd6e:d157:2b4:cdbf:0:ff:fe00:3c0e/64 valid preferred rloc
D: 3100141 [DL]        fd6e:d157:2b4:cdbf:f7ba:38cf:b770:ad1f/64 valid preferred
D: 3100149 [DL]        fe80::645d:b1e:4628:2488/64 valid preferred
D: 3100155 [DL]OpenThread State Changed (Flags: 0x00000001)
D: 3100160 [DL]   Thread Unicast Addresses:
D: 3100164 [DL]        fd41:8102:3c8a:1:8842:8ece:3871:5cee/64 valid preferred
D: 3100171 [DL]        fd6e:d157:2b4:cdbf:0:ff:fe00:3c0e/64 valid preferred rloc
D: 3100179 [DL]        fd6e:d157:2b4:cdbf:f7ba:38cf:b770:ad1f/64 valid preferred
D: 3100186 [DL]        fe80::645d:b1e:4628:2488/64 valid preferred
I: 3100193 [EM]<<< [E:38207r S:35051 M:67378431] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [A18B] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:65)
D: 3100208 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 70)
D: 3100216 [DL]Using Thread extended MAC for hostname.
I: 3100221 [DIS]Advertise operational node 5329CE4A2334A18B-000000001EAD6F46
E: 3100227 [SVR]Operational advertising failed: 3
D: 3100356 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3100744 [DL]SRP update succeeded
I: 3100747 [SVR]Server initialization complete
I: 3100752 [DIS]Updating services using commissioning mode 0
D: 3100757 [DL]Using Thread extended MAC for hostname.
I: 3100762 [DIS]Advertise operational node 5329CE4A2334A18B-000000001EAD6F46
I: 3100769 [DL]advertising srp service: 5329CE4A2334A18B-000000001EAD6F46._matter._tcp
I: 3100779 [SWU]Stopping the watchdog timer
I: 3100783 [SWU]Starting the periodic query timer, timeout: 86400 seconds
D: 3102336 [DL]SRP update succeeded
D: 3102816 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 3105324 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 3105396 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3107856 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 3110364 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 3110436 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3112417 [DL]OpenThread State Changed (Flags: 0x00000064)
D: 3112422 [DL]   Device Role: ROUTER
D: 3112896 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 3115404 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 3115476 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3117937 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 3120444 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 3120517 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3122977 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 3125484 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 3125557 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3128017 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 3130524 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 3130597 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3133057 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 3135565 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 3135637 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3138098 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 3140605 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 3140678 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3143138 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 3145645 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 3145778 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3148238 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 3150746 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 3150818 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3153278 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 3155786 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 3155858 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3158319 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
Here are successful attempt on Android part 1.
I: 3249515 [DL]Current number of connections: 1/1
I: 3249520 [DL]BLE connection established (ConnId: 0x00)
I: 3249525 [DL]CHIPoBLE advertising stopped
I: 3249529 [DL]NFC Tag emulation stopped
D: 3250296 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3250304 [BLE]local and remote recv window sizes = 5
I: 3250308 [BLE]selected BTP version 4
I: 3250312 [BLE]using BTP fragment sizes rx 244 / tx 244.
D: 3250319 [DL]ConnId: 0x00, New CCCD value: 0x0002
D: 3250323 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 6)
D: 3250331 [IN]BLE EndPoint 0x20011be8 Connection Complete
I: 3250336 [DL]CHIPoBLE connection established (ConnId: 0x00, GATT MTU: 247)
D: 3250394 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3250485 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3250493 [EM]>>> [E:5010r S:0 M:183108567] (U) Msg RX from 0:9563C899FDF389B5 [0000] to 0000000000000000 --- Type 0000:20 (SecureChannel:PBKDFParamRequest) (B:98)
I: 3250508 [EM]<<< [E:5010r S:0 M:172498954] (U) Msg TX from 0000000000000000 to 0:9563C899FDF389B5 [0000] [BLE] --- Type 0000:21 (SecureChannel:PBKDFParamResponse) (B:154)
D: 3250523 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 159)
I: 3250531 [SVR]Commissioning session establishment step started
D: 3250634 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3250665 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3250672 [EM]>>> [E:5010r S:0 M:183108568] (U) Msg RX from 0:9563C899FDF389B5 [0000] to 0000000000000000 --- Type 0000:22 (SecureChannel:PASE_Pake1) (B:92)
I: 3250712 [EM]<<< [E:5010r S:0 M:172498955] (U) Msg TX from 0000000000000000 to 0:9563C899FDF389B5 [0000] [BLE] --- Type 0000:23 (SecureChannel:PASE_Pake2) (B:127)
D: 3250726 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 132)
D: 3250784 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3250815 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3250823 [EM]>>> [E:5010r S:0 M:183108569] (U) Msg RX from 0:9563C899FDF389B5 [0000] to 0000000000000000 --- Type 0000:24 (SecureChannel:PASE_Pake3) (B:59)
I: 3250837 [EM]<<< [E:5010r S:0 M:172498956] (U) Msg TX from 0000000000000000 to 0:9563C899FDF389B5 [0000] [BLE] --- Type 0000:40 (SecureChannel:StatusReport) (B:30)
D: 3250852 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 35)
I: 3250861 [SC]SecureSession[0x20004500, LSID:57611]: State change 'kEstablishing' --> 'kActive'
D: 3250869 [IN]SecureSession[0x20004500]: Activated - Type:1 LSID:57611
D: 3250876 [IN]New secure session activated for device <FFFFFFFB00000000, 0>, LSID:57611 PSID:63232!
I: 3250885 [SVR]Commissioning completed session establishment step
I: 3250891 [DIS]Updating services using commissioning mode 0
E: 3250896 [DIS]Failed to remove advertised services: 3
E: 3250901 [DIS]Failed to finalize service update: 3
D: 3250906 [DL]CHIPoBLE advertising set to off
I: 3250910 [SVR]Device completed Rendezvous process
D: 3250919 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3250927 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3250935 [EM]>>> [E:5011r S:57611 M:220549695] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3250949 [IM]Received Read request
I: 3250953 [EM]<<< [E:5011r S:57611 M:240576220] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:67)
D: 3250967 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 72)
D: 3251054 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3251062 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3251070 [EM]>>> [E:5012r S:57611 M:220549696] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3251084 [IM]Received Read request
I: 3251088 [EM]<<< [E:5012r S:57611 M:240576221] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:67)
D: 3251102 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 72)
D: 3251279 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3251288 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3251295 [EM]>>> [E:5013r S:57611 M:220549697] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3251309 [IM]Received Read request
I: 3251313 [EM]<<< [E:5013r S:57611 M:240576222] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:82)
D: 3251327 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 87)
D: 3251459 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3251468 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3251475 [EM]>>> [E:5014r S:57611 M:220549698] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3251489 [IM]Received Read request
I: 3251493 [EM]<<< [E:5014r S:57611 M:240576223] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:66)
D: 3251507 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 3251594 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3251603 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3251610 [EM]>>> [E:5015r S:57611 M:220549699] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3251624 [IM]Received Read request
I: 3251628 [EM]<<< [E:5015r S:57611 M:240576224] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:69)
D: 3251642 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 74)
D: 3251729 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3252000 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3252008 [EM]>>> [E:5016r S:57611 M:220549700] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3252021 [IM]Received Read request
I: 3252026 [EM]<<< [E:5016r S:57611 M:240576225] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:66)
D: 3252040 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 3252134 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3252143 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3252151 [EM]>>> [E:5017r S:57611 M:220549701] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3252164 [IM]Received Read request
I: 3252168 [EM]<<< [E:5017r S:57611 M:240576226] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:66)
D: 3252182 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 3252269 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3252278 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3252285 [EM]>>> [E:5018r S:57611 M:220549702] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3252299 [IM]Received Read request
I: 3252303 [EM]<<< [E:5018r S:57611 M:240576227] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:65)
D: 3252317 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 70)
D: 3252404 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3252412 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3252420 [EM]>>> [E:5019r S:57611 M:220549703] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:0A (IM:TimedRequest) (B:39)
I: 3252434 [EM]<<< [E:5019r S:57611 M:240576228] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:01 (IM:StatusResponse) (B:38)
D: 3252448 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 43)
D: 3252539 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3252548 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3252555 [EM]>>> [E:5019r S:57611 M:220549704] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:65)
I: 3252570 [FS]GeneralCommissioning: Received ArmFailSafe (240s)
I: 3252576 [EM]<<< [E:5019r S:57611 M:240576229] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:66)
D: 3252591 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 3252674 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3252683 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3252690 [EM]>>> [E:5020r S:57611 M:220549705] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:62)
I: 3252705 [ZCL]OpCreds: Certificate Chain request received for PAI
I: 3252712 [EM]<<< [E:5020r S:57611 M:240576230] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:527)
D: 3252727 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 3252809 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3252817 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 3252899 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3252907 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 48)
D: 3252989 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3252998 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3253005 [EM]>>> [E:5021r S:57611 M:220549706] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:62)
I: 3253020 [ZCL]OpCreds: Certificate Chain request received for DAC
I: 3253027 [EM]<<< [E:5021r S:57611 M:240576231] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:556)
D: 3253042 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 3253124 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3253132 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 3253214 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3253222 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 77)
D: 3253304 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3255599 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 3257446 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3257454 [EM]>>> [E:5022r S:57611 M:220549707] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:96)
I: 3257469 [ZCL]OpCreds: Received a CSRRequest command
I: 3257479 [ZCL]OpCreds: AllocatePendingOperationalKey succeeded
I: 3257487 [ZCL]OpCreds: CSRRequest successful.
I: 3257492 [EM]<<< [E:5022r S:57611 M:240576232] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:393)
D: 3257507 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 3257579 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3257587 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 156)
D: 3257669 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3260099 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 3261451 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3261458 [EM]>>> [E:5023r S:57611 M:220549708] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3261472 [IM]Received Read request
I: 3261476 [EM]<<< [E:5023r S:57611 M:240576233] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:66)
D: 3261490 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 3261584 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3261629 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 3261676 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3261684 [EM]>>> [E:5024r S:57611 M:220549709] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:324)
I: 3261699 [ZCL]OpCreds: Received an AddTrustedRootCertificate command
I: 3261707 [ZCL]OpCreds: AddTrustedRootCertificate successful.
I: 3261713 [EM]<<< [E:5024r S:57611 M:240576234] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:63)
D: 3261728 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 68)
D: 3261809 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3261854 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 3261905 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 3261993 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3262001 [EM]>>> [E:5025r S:57611 M:220549710] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:641)
I: 3262016 [ZCL]OpCreds: Received an AddNOC command
I: 3262021 [FP]Validating NOC chain
I: 3262029 [FP]NOC chain validation successful
I: 3262033 [FP]Added new fabric at index: 0x1
I: 3262038 [FP]Assigned compressed fabric ID: 0xA82B8EF5C959FAE5, node ID: 0xC2032ACD15199E15
I: 3262046 [TS]Last Known Good Time: 2023-10-14T01:16:48
I: 3262051 [TS]New proposed Last Known Good Time: 2025-04-09T01:54:22
I: 3262057 [TS]Updating pending Last Known Good Time to 2025-04-09T01:54:22
I: 3262082 [ZCL]OpCreds: ACL entry created for Fabric index 0x1 CASE Admin Subject 0xFFFFFFFD00000001
D: 3262091 [DL]Using Thread extended MAC for hostname.
I: 3262096 [DIS]Advertise operational node A82B8EF5C959FAE5-C2032ACD15199E15
E: 3262102 [SVR]Operational advertising failed: 3
I: 3262107 [ZCL]OpCreds: successfully created fabric index 0x1 via AddNOC
I: 3262114 [EM]<<< [E:5025r S:57611 M:240576235] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [FAE5] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:66)
D: 3262129 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
E: 3262137 [DL]Long dispatch time: 143 ms, for event type 16388
D: 3262214 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3262223 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3262231 [EM]>>> [E:5026r S:57611 M:220549711] (S) Msg RX from 1:FFFFFFFB00000000 [FAE5] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3262244 [IM]Received Read request
I: 3262249 [EM]<<< [E:5026r S:57611 M:240576236] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [FAE5] [BLE] --- Type 0001:05 (IM:ReportData) (B:74)
D: 3262262 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 79)
D: 3262349 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3262358 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3262366 [EM]>>> [E:5027r S:57611 M:220549712] (S) Msg RX from 1:FFFFFFFB00000000 [FAE5] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3262379 [IM]Received Read request
I: 3262384 [EM]<<< [E:5027r S:57611 M:240576237] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [FAE5] [BLE] --- Type 0001:05 (IM:ReportData) (B:74)
D: 3262397 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 79)
D: 3262484 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3262493 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3262501 [EM]>>> [E:5028r S:57611 M:220549713] (S) Msg RX from 1:FFFFFFFB00000000 [FAE5] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3262514 [IM]Received Read request
I: 3262519 [EM]<<< [E:5028r S:57611 M:240576238] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [FAE5] [BLE] --- Type 0001:05 (IM:ReportData) (B:74)
D: 3262533 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 79)
D: 3262619 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3262628 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3262636 [EM]>>> [E:5029r S:57611 M:220549714] (S) Msg RX from 1:FFFFFFFB00000000 [FAE5] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3262649 [IM]Received Read request
I: 3262654 [EM]<<< [E:5029r S:57611 M:240576239] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [FAE5] [BLE] --- Type 0001:05 (IM:ReportData) (B:74)
D: 3262667 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 79)
D: 3262754 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3262763 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3262771 [EM]>>> [E:5030r S:57611 M:220549715] (S) Msg RX from 1:FFFFFFFB00000000 [FAE5] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3262784 [IM]Received Read request
I: 3262789 [EM]<<< [E:5030r S:57611 M:240576240] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [FAE5] [BLE] --- Type 0001:05 (IM:ReportData) (B:74)
D: 3262802 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 79)
D: 3262889 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3262898 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3262906 [EM]>>> [E:5031r S:57611 M:220549716] (S) Msg RX from 1:FFFFFFFB00000000 [FAE5] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3262919 [IM]Received Read request
I: 3262924 [EM]<<< [E:5031r S:57611 M:240576241] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [FAE5] [BLE] --- Type 0001:05 (IM:ReportData) (B:74)
D: 3262937 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 79)
D: 3263024 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3263033 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3263041 [EM]>>> [E:5032r S:57611 M:220549717] (S) Msg RX from 1:FFFFFFFB00000000 [FAE5] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3263054 [IM]Received Read request
I: 3263059 [EM]<<< [E:5032r S:57611 M:240576242] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [FAE5] [BLE] --- Type 0001:05 (IM:ReportData) (B:74)
D: 3263073 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 79)
D: 3263159 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3263168 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3263176 [EM]>>> [E:5033r S:57611 M:220549718] (S) Msg RX from 1:FFFFFFFB00000000 [FAE5] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3263189 [IM]Received Read request
I: 3263194 [EM]<<< [E:5033r S:57611 M:240576243] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [FAE5] [BLE] --- Type 0001:05 (IM:ReportData) (B:74)
D: 3263207 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 79)
D: 3263294 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3263303 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3263311 [EM]>>> [E:5034r S:57611 M:220549719] (S) Msg RX from 1:FFFFFFFB00000000 [FAE5] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3263324 [IM]Received Read request
I: 3263329 [EM]<<< [E:5034r S:57611 M:240576244] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [FAE5] [BLE] --- Type 0001:05 (IM:ReportData) (B:74)
D: 3263342 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 79)
D: 3263429 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3263438 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3263446 [EM]>>> [E:5035r S:57611 M:220549720] (S) Msg RX from 1:FFFFFFFB00000000 [FAE5] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3263459 [IM]Received Read request
I: 3263464 [EM]<<< [E:5035r S:57611 M:240576245] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [FAE5] [BLE] --- Type 0001:05 (IM:ReportData) (B:74)
D: 3263477 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 79)
D: 3263564 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3263573 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3263581 [EM]>>> [E:5036r S:57611 M:220549721] (S) Msg RX from 1:FFFFFFFB00000000 [FAE5] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3263594 [IM]Received Read request
I: 3263599 [EM]<<< [E:5036r S:57611 M:240576246] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [FAE5] [BLE] --- Type 0001:05 (IM:ReportData) (B:74)
D: 3263613 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 79)
D: 3263699 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3263708 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3263716 [EM]>>> [E:5037r S:57611 M:220549722] (S) Msg RX from 1:FFFFFFFB00000000 [FAE5] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:52)
D: 3263729 [IM]Received Read request
I: 3263734 [EM]<<< [E:5037r S:57611 M:240576247] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [FAE5] [BLE] --- Type 0001:05 (IM:ReportData) (B:67)
D: 3263747 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 72)
D: 3263834 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3265455 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3265463 [EM]>>> [E:5038r S:57611 M:220549723] (S) Msg RX from 1:FFFFFFFB00000000 [FAE5] to 0000000000000000 --- Type 0001:0A (IM:TimedRequest) (B:39)
I: 3265477 [EM]<<< [E:5038r S:57611 M:240576248] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [FAE5] [BLE] --- Type 0001:01 (IM:StatusResponse) (B:38)
D: 3265491 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 43)
D: 3265544 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3265553 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3265561 [EM]>>> [E:5038r S:57611 M:220549724] (S) Msg RX from 1:FFFFFFFB00000000 [FAE5] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:66)
I: 3265575 [FS]GeneralCommissioning: Received ArmFailSafe (270s)
I: 3265582 [EM]<<< [E:5038r S:57611 M:240576249] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [FAE5] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:66)
D: 3265597 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 3265679 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3265688 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3265696 [EM]>>> [E:5039r S:57611 M:220549725] (S) Msg RX from 1:FFFFFFFB00000000 [FAE5] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3265709 [IM]Received Read request
Here are successful attempt on Android part 2.
I: 3265714 [EM]<<< [E:5039r S:57611 M:240576250] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [FAE5] [BLE] --- Type 0001:05 (IM:ReportData) (B:66)
D: 3265728 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 3265814 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3265823 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3265831 [EM]>>> [E:5040r S:57611 M:220549726] (S) Msg RX from 1:FFFFFFFB00000000 [FAE5] to 0000000000000000 --- Type 0001:0A (IM:TimedRequest) (B:39)
I: 3265845 [EM]<<< [E:5040r S:57611 M:240576251] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [FAE5] [BLE] --- Type 0001:01 (IM:StatusResponse) (B:38)
D: 3265859 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 43)
D: 3265949 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3265959 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3265967 [EM]>>> [E:5040r S:57611 M:220549727] (S) Msg RX from 1:FFFFFFFB00000000 [FAE5] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:102)
I: 3265983 [EM]<<< [E:5040r S:57611 M:240576252] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [FAE5] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:66)
D: 3265998 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 3266084 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3266093 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3266101 [EM]>>> [E:5041r S:57611 M:220549728] (S) Msg RX from 1:FFFFFFFB00000000 [FAE5] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3266114 [IM]Received Read request
I: 3266119 [EM]<<< [E:5041r S:57611 M:240576253] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [FAE5] [BLE] --- Type 0001:05 (IM:ReportData) (B:66)
D: 3266132 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 3266219 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3266228 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3266236 [EM]>>> [E:5042r S:57611 M:220549729] (S) Msg RX from 1:FFFFFFFB00000000 [FAE5] to 0000000000000000 --- Type 0001:0A (IM:TimedRequest) (B:39)
I: 3266250 [EM]<<< [E:5042r S:57611 M:240576254] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [FAE5] [BLE] --- Type 0001:01 (IM:StatusResponse) (B:38)
D: 3266264 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 43)
D: 3266354 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3266363 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3266372 [EM]>>> [E:5042r S:57611 M:220549730] (S) Msg RX from 1:FFFFFFFB00000000 [FAE5] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:73)
D: 3266410 [DL]OpenThread State Changed (Flags: 0x1006c100)
D: 3266415 [DL]   Network Name: OpenThread
D: 3266419 [DL]   PAN Id: 0x6B67
D: 3266422 [DL]   Extended PAN Id: 0x8B28D6D445476F03
D: 3266427 [DL]   Channel: 24
D: 3266429 [DL]   Mesh Prefix: fdde:ad00:beef::/64
D: 3266436 [DL]OpenThread State Changed (Flags: 0x1100100d)
D: 3266442 [DL]   Device Role: DETACHED
D: 3266446 [DL]   Thread Unicast Addresses:
D: 3266450 [DL]        fdde:ad00:beef:0:5195:bb81:9898:975f/64 valid preferred
D: 3266456 [DL]        fe80::3c45:88f0:3784:291e/64 valid preferred
I: 3267809 [DL]SRP Client was started, detected server: fd6e:d157:02b4:cdbf:6864:fb66:d7b6:d6fc
I: 3267818 [ZCL]ThreadDiagnosticsDelegate: OnConnectionStatusChanged
D: 3267824 [DL]OpenThread State Changed (Flags: 0x301932b7)
D: 3267829 [DL]   Device Role: CHILD
D: 3267832 [DL]   Network Name: ST-3011076154
D: 3267836 [DL]   PAN Id: 0x6B67
D: 3267840 [DL]   Extended PAN Id: 0x8B28D6D445476F03
D: 3267844 [DL]   Channel: 24
D: 3267847 [DL]   Mesh Prefix: fd6e:d157:2b4:cdbf::/64
D: 3267852 [DL]   Partition Id: 0x78624E99
D: 3267856 [DL]   Thread Unicast Addresses:
D: 3267860 [DL]        fd41:8102:3c8a:1:e2d:3318:d087:8d3c/64 valid preferred
D: 3267867 [DL]        fd6e:d157:2b4:cdbf:0:ff:fe00:3c0f/64 valid preferred rloc
D: 3267874 [DL]        fd6e:d157:2b4:cdbf:5195:bb81:9898:975f/64 valid preferred
D: 3267881 [DL]        fe80::3c45:88f0:3784:291e/64 valid preferred
E: 3267991 [DL]Long dispatch time: 174 ms, for event type 32779
D: 3267997 [DL]OpenThread State Changed (Flags: 0x00000001)
D: 3268003 [DL]   Thread Unicast Addresses:
D: 3268007 [DL]        fd41:8102:3c8a:1:e2d:3318:d087:8d3c/64 valid preferred
D: 3268014 [DL]        fd6e:d157:2b4:cdbf:0:ff:fe00:3c0f/64 valid preferred rloc
D: 3268021 [DL]        fd6e:d157:2b4:cdbf:5195:bb81:9898:975f/64 valid preferred
D: 3268028 [DL]        fe80::3c45:88f0:3784:291e/64 valid preferred
I: 3268036 [EM]<<< [E:5042r S:57611 M:240576255] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [FAE5] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:65)
D: 3268052 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 70)
D: 3268060 [DL]Using Thread extended MAC for hostname.
I: 3268065 [DIS]Advertise operational node A82B8EF5C959FAE5-C2032ACD15199E15
E: 3268072 [SVR]Operational advertising failed: 3
D: 3268110 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 3268124 [DL]SRP update succeeded
I: 3268128 [SVR]Server initialization complete
I: 3268132 [DIS]Updating services using commissioning mode 0
D: 3268137 [DL]Using Thread extended MAC for hostname.
I: 3268142 [DIS]Advertise operational node A82B8EF5C959FAE5-C2032ACD15199E15
I: 3268149 [DL]advertising srp service: A82B8EF5C959FAE5-C2032ACD15199E15._matter._tcp
I: 3268159 [SWU]Stopping the watchdog timer
I: 3268163 [SWU]Starting the periodic query timer, timeout: 86400 seconds
D: 3269697 [DL]SRP update succeeded
I: 3270233 [EM]>>> [E:22172r S:0 M:220016613] (U) Msg RX from 0:798752CD8D53BDE5 [0000] to 0000000000000000 --- Type 0000:30 (SecureChannel:CASE_Sigma1) (B:196)
I: 3270247 [IN]CASE Server received Sigma1 message . Starting handshake. EC 0x20006668
I: 3270255 [EM]<<< [E:22172r S:0 M:172498957 (Ack:220016613)] (U) Msg TX from 0000000000000000 to 0:798752CD8D53BDE5 [0000] [UDP:[fd41:8102:3c8a:1:3040:80ff:1261:2b27]:54369] --- Type 0000:10 (SecureChannel:StandaloneAck) (B:26)
I: 3270276 [SC]Received Sigma1 msg
I: 3270283 [SC]CASE matched destination ID: fabricIndex 1, NodeID 0xC2032ACD15199E15
I: 3270305 [EM]<<< [E:22172r S:0 M:172498958 (Ack:220016613)] (U) Msg TX from 0000000000000000 to 0:798752CD8D53BDE5 [0000] [UDP:[fd41:8102:3c8a:1:3040:80ff:1261:2b27]:54369] --- Type 0000:31 (SecureChannel:CASE_Sigma2) (B:822)
I: 3270327 [EM]??1 [E:22172r S:0 M:172498958] (U) Msg Retransmission to 0:0000000000000000 in 1893ms [State:Active II:500 AI:300 AT:4000]
I: 3270339 [SC]Sent Sigma2 msg
D: 3270630 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 3271050 [EM]>>> [E:22172r S:0 M:220016614 (Ack:172498958)] (U) Msg RX from 0:798752CD8D53BDE5 [0000] to 0000000000000000 --- Type 0000:32 (SecureChannel:CASE_Sigma3) (B:669)
I: 3271066 [EM]<<< [E:22172r S:0 M:172498959 (Ack:220016614)] (U) Msg TX from 0000000000000000 to 0:798752CD8D53BDE5 [0000] [UDP:[fd41:8102:3c8a:1:3040:80ff:1261:2b27]:54369] --- Type 0000:10 (SecureChannel:StandaloneAck) (B:26)
I: 3271086 [SC]Received Sigma3 msg
E: 3271092 [SC]The device does not support GetClock_RealTimeMS() API: 3.  Falling back to Last Known Good UTC Time
I: 3271376 [EM]<<< [E:22172r S:0 M:172498960 (Ack:220016614)] (U) Msg TX from 0000000000000000 to 0:798752CD8D53BDE5 [0000] [UDP:[fd41:8102:3c8a:1:3040:80ff:1261:2b27]:54369] --- Type 0000:40 (SecureChannel:StatusReport) (B:34)
I: 3271397 [EM]??1 [E:22172r S:0 M:172498960] (U) Msg Retransmission to 0:0000000000000000 in 1868ms [State:Active II:500 AI:300 AT:4000]
I: 3271410 [SC]SecureSession[0x200045d8, LSID:57612]: State change 'kEstablishing' --> 'kActive'
D: 3271419 [IN]SecureSession[0x200045d8]: Activated - Type:2 LSID:57612
D: 3271427 [IN]New secure session activated for device <042B599B7E1E363B, 1>, LSID:57612 PSID:30631!
I: 3271436 [IN]CASE Session established to peer: <042B599B7E1E363B, 1>
D: 3271442 [IN]SecureSession[0x200046b0]: Allocated Type:2 LSID:57613
E: 3271449 [DL]Long dispatch time: 341 ms, for event type 2
I: 3271454 [EM]>>> [E:22172r S:0 M:220016615 (Ack:172498960)] (U) Msg RX from 0:798752CD8D53BDE5 [0000] to 0000000000000000 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:26)
I: 3271480 [EM]>>> [E:22173r S:57612 M:53306773] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0001:03 (IM:SubscribeRequest) (B:59)
D: 3271494 [IM]Received Subscribe request
I: 3271498 [DMG]Final negotiated min/max parameters: Min = 2s, Max = 30s
I: 3271506 [EM]<<< [E:22173r S:57612 M:242209814 (Ack:53306773)] (S) Msg TX from C2032ACD15199E15 to 1:042B599B7E1E363B [FAE5] [UDP:[fd41:8102:3c8a:1:3040:80ff:1261:2b27]:54369] --- Type 0001:05 (IM:ReportData) (B:75)
I: 3271526 [EM]??1 [E:22173r S:57612 M:242209814] (S) Msg Retransmission to 1:042B599B7E1E363B in 1860ms [State:Active II:500 AI:300 AT:4000]
I: 3271552 [EM]>>> [E:22173r S:57612 M:53306774 (Ack:242209814)] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0001:01 (IM:StatusResponse) (B:42)
I: 3271567 [IM]Received status response, status is 0x00
I: 3271573 [EM]<<< [E:22173r S:57612 M:242209815 (Ack:53306774)] (S) Msg TX from C2032ACD15199E15 to 1:042B599B7E1E363B [FAE5] [UDP:[fd41:8102:3c8a:1:3040:80ff:1261:2b27]:54369] --- Type 0001:04 (IM:SubscribeResponse) (B:48)
I: 3271594 [EM]??1 [E:22173r S:57612 M:242209815] (S) Msg Retransmission to 1:042B599B7E1E363B in 1909ms [State:Active II:500 AI:300 AT:4000]
I: 3271606 [DMG]Registered a ReadHandler that will schedule a report between system Timestamp: 0x000000000031F386 and system Timestamp 0x00000000003260E6.
I: 3271623 [EM]>>> [E:22173r S:57612 M:53306775 (Ack:242209815)] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
I: 3271642 [EM]>>> [E:22174r S:57612 M:53306776] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0001:08 (IM:InvokeCommandRequest) (B:62)
I: 3271656 [FS]GeneralCommissioning: Received CommissioningComplete
I: 3271768 [FP]Metadata for Fabric 0x1 persisted to storage.
I: 3272070 [TS]Committing Last Known Good Time to storage: 2025-04-09T01:54:22
I: 3272160 [ZCL]OpCreds: Fabric index 0x1 was committed to storage. Compressed Fabric Id 0xA82B8EF5C959FAE5, FabricId EB7B0CD142D4C6DE, NodeId C2032ACD15199E15, VendorId 0x110A
I: 3272205 [FS]GeneralCommissioning: Successfully commited pending fabric data
I: 3272212 [FS]Fail-safe cleanly disarmed
I: 3272216 [EM]<<< [E:22174r S:57612 M:242209816 (Ack:53306776)] (S) Msg TX from C2032ACD15199E15 to 1:042B599B7E1E363B [FAE5] [UDP:[fd41:8102:3c8a:1:3040:80ff:1261:2b27]:54369] --- Type 0001:09 (IM:InvokeCommandResponse) (B:73)
I: 3272237 [EM]??1 [E:22174r S:57612 M:242209816] (S) Msg Retransmission to 1:042B599B7E1E363B in 1854ms [State:Active II:500 AI:300 AT:4000]
I: 3272250 [SWU]Device commissioned, schedule a default provider query
I: 3272256 [SVR]Commissioning completed successfully
I: 3272263 [DIS]Updating services using commissioning mode 0
D: 3272269 [DL]Using Thread extended MAC for hostname.
I: 3272276 [DIS]Advertise operational node A82B8EF5C959FAE5-C2032ACD15199E15
D: 3272282 [DL]CHIPoBLE advertising set to off
D: 3272287 [IN]Expiring all PASE sessions
D: 3272290 [IN]SecureSession[0x20004500]: MarkForEviction Type:1 LSID:57611
I: 3272297 [SC]SecureSession[0x20004500, LSID:57611]: State change 'kActive' --> 'kPendingEviction'
D: 3272306 [IN]SecureSession[0x20004500]: Released - Type:1 LSID:57611
D: 3272312 [IN]Clearing BLE pending packets.
I: 3272316 [BLE]Releasing end point's BLE connection back to application.
I: 3272323 [DL]Closing BLE GATT connection (ConnId 00)
E: 3272353 [DL]Long dispatch time: 103 ms, for event type 32783
I: 3272359 [EM]>>> [E:22174r S:57612 M:53306777 (Ack:242209816)] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
I: 3272376 [EM]>>> [E:22175r S:57612 M:53306778] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0001:02 (IM:ReadRequest) (B:49)
D: 3272389 [IM]Received Read request
I: 3272393 [DL]Current number of connections: 0/1
I: 3272399 [EM]<<< [E:22175r S:57612 M:242209817 (Ack:53306778)] (S) Msg TX from C2032ACD15199E15 to 1:042B599B7E1E363B [FAE5] [UDP:[fd41:8102:3c8a:1:3040:80ff:1261:2b27]:54369] --- Type 0001:05 (IM:ReportData) (B:71)
I: 3272418 [EM]??1 [E:22175r S:57612 M:242209817] (S) Msg Retransmission to 1:042B599B7E1E363B in 1903ms [State:Active II:500 AI:300 AT:4000]
I: 3272431 [DL]BLE GAP connection terminated (reason 0x16)
I: 3272442 [EM]>>> [E:22175r S:57612 M:53306779 (Ack:242209817)] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
I: 3272460 [EM]>>> [E:22176r S:57612 M:53306780] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0001:02 (IM:ReadRequest) (B:48)
D: 3272474 [IM]Received Read request
I: 3272481 [EM]<<< [E:22176r S:57612 M:242209818 (Ack:53306780)] (S) Msg TX from C2032ACD15199E15 to 1:042B599B7E1E363B [FAE5] [UDP:[fd41:8102:3c8a:1:3040:80ff:1261:2b27]:54369] --- Type 0001:05 (IM:ReportData) (B:788)
I: 3272501 [EM]??1 [E:22176r S:57612 M:242209818] (S) Msg Retransmission to 1:042B599B7E1E363B in 1889ms [State:Active II:500 AI:300 AT:4000]
I: 3272584 [EM]>>> [E:22176r S:57612 M:53306781 (Ack:242209818)] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
I: 3272602 [EM]>>> [E:22177r S:57612 M:53306782] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0001:02 (IM:ReadRequest) (B:48)
D: 3272616 [IM]Received Read request
I: 3272621 [EM]<<< [E:22177r S:57612 M:242209819 (Ack:53306782)] (S) Msg TX from C2032ACD15199E15 to 1:042B599B7E1E363B [FAE5] [UDP:[fd41:8102:3c8a:1:3040:80ff:1261:2b27]:54369] --- Type 0001:05 (IM:ReportData) (B:214)
I: 3272641 [EM]??1 [E:22177r S:57612 M:242209819] (S) Msg Retransmission to 1:042B599B7E1E363B in 1852ms [State:Active II:500 AI:300 AT:4000]
I: 3272675 [EM]>>> [E:22177r S:57612 M:53306783 (Ack:242209819)] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
I: 3272693 [EM]>>> [E:22178r S:57612 M:53306784] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0001:02 (IM:ReadRequest) (B:48)
D: 3272706 [IM]Received Read request
I: 3272711 [EM]<<< [E:22178r S:57612 M:242209820 (Ack:53306784)] (S) Msg TX from C2032ACD15199E15 to 1:042B599B7E1E363B [FAE5] [UDP:[fd41:8102:3c8a:1:3040:80ff:1261:2b27]:54369] --- Type 0001:05 (IM:ReportData) (B:226)
I: 3272731 [EM]??1 [E:22178r S:57612 M:242209820] (S) Msg Retransmission to 1:042B599B7E1E363B in 1840ms [State:Active II:500 AI:300 AT:4000]
I: 3272767 [EM]>>> [E:22178r S:57612 M:53306785 (Ack:242209820)] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
I: 3272785 [EM]>>> [E:22179r S:57612 M:53306786] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0001:02 (IM:ReadRequest) (B:48)
D: 3272799 [IM]Received Read request
I: 3272804 [EM]<<< [E:22179r S:57612 M:242209821 (Ack:53306786)] (S) Msg TX from C2032ACD15199E15 to 1:042B599B7E1E363B [FAE5] [UDP:[fd41:8102:3c8a:1:3040:80ff:1261:2b27]:54369] --- Type 0001:05 (IM:ReportData) (B:176)
I: 3272824 [EM]??1 [E:22179r S:57612 M:242209821] (S) Msg Retransmission to 1:042B599B7E1E363B in 1890ms [State:Active II:500 AI:300 AT:4000]
I: 3272854 [EM]>>> [E:22179r S:57612 M:53306787 (Ack:242209821)] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
I: 3272873 [EM]>>> [E:22180r S:57612 M:53306788] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0001:02 (IM:ReadRequest) (B:46)
D: 3272886 [IM]Received Read request
I: 3272892 [EM]<<< [E:22180r S:57612 M:242209822 (Ack:53306788)] (S) Msg TX from C2032ACD15199E15 to 1:042B599B7E1E363B [FAE5] [UDP:[fd41:8102:3c8a:1:3040:80ff:1261:2b27]:54369] --- Type 0001:05 (IM:ReportData) (B:746)
I: 3272913 [EM]??1 [E:22180r S:57612 M:242209822] (S) Msg Retransmission to 1:042B599B7E1E363B in 1897ms [State:Active II:500 AI:300 AT:4000]
I: 3272994 [EM]>>> [E:22180r S:57612 M:53306789 (Ack:242209822)] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
I: 3273013 [EM]>>> [E:22181r S:57612 M:53306790] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3273026 [IM]Received Read request
I: 3273031 [EM]<<< [E:22181r S:57612 M:242209823 (Ack:53306790)] (S) Msg TX from C2032ACD15199E15 to 1:042B599B7E1E363B [FAE5] [UDP:[fd41:8102:3c8a:1:3040:80ff:1261:2b27]:54369] --- Type 0001:05 (IM:ReportData) (B:70)
I: 3273050 [EM]??1 [E:22181r S:57612 M:242209823] (S) Msg Retransmission to 1:042B599B7E1E363B in 1892ms [State:Active II:500 AI:300 AT:4000]
I: 3273072 [EM]>>> [E:22181r S:57612 M:53306791 (Ack:242209823)] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
I: 3273091 [EM]>>> [E:22182r S:57612 M:53306792] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3273104 [IM]Received Read request
I: 3273109 [EM]<<< [E:22182r S:57612 M:242209824 (Ack:53306792)] (S) Msg TX from C2032ACD15199E15 to 1:042B599B7E1E363B [FAE5] [UDP:[fd41:8102:3c8a:1:3040:80ff:1261:2b27]:54369] --- Type 0001:05 (IM:ReportData) (B:70)
I: 3273129 [EM]??1 [E:22182r S:57612 M:242209824] (S) Msg Retransmission to 1:042B599B7E1E363B in 1908ms [State:Active II:500 AI:300 AT:4000]
I: 3273151 [EM]>>> [E:22182r S:57612 M:53306793 (Ack:242209824)] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
I: 3273170 [EM]>>> [E:22183r S:57612 M:53306794] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0001:02 (IM:ReadRequest) (B:48)
D: 3273183 [IM]Received Read request
I: 3273188 [EM]<<< [E:22183r S:57612 M:242209825 (Ack:53306794)] (S) Msg TX from C2032ACD15199E15 to 1:042B599B7E1E363B [FAE5] [UDP:[fd41:8102:3c8a:1:3040:80ff:1261:2b27]:54369] --- Type 0001:05 (IM:ReportData) (B:182)
I: 3273208 [EM]??1 [E:22183r S:57612 M:242209825] (S) Msg Retransmission to 1:042B599B7E1E363B in 1831ms [State:Active II:500 AI:300 AT:4000]
I: 3273244 [EM]>>> [E:22183r S:57612 M:53306795 (Ack:242209825)] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
I: 3273322 [EM]>>> [E:22184r S:57612 M:53306796] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0001:08 (IM:InvokeCommandRequest) (B:85)
I: 3273337 [ZCL]OpCreds: Received an UpdateFabricLabel command
I: 3273377 [FP]Metadata for Fabric 0x1 persisted to storage.
I: 3273383 [EM]<<< [E:22184r S:57612 M:242209826 (Ack:53306796)] (S) Msg TX from C2032ACD15199E15 to 1:042B599B7E1E363B [FAE5] [UDP:[fd41:8102:3c8a:1:3040:80ff:1261:2b27]:54369] --- Type 0001:09 (IM:InvokeCommandResponse) (B:73)
I: 3273404 [EM]??1 [E:22184r S:57612 M:242209826] (S) Msg Retransmission to 1:042B599B7E1E363B in 1845ms [State:Active II:500 AI:300 AT:4000]
I: 3273427 [EM]>>> [E:22184r S:57612 M:53306797 (Ack:242209826)] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
I: 3275054 [EM]>>> [E:22185r S:57612 M:53306798] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0001:06 (IM:WriteRequest) (B:74)
D: 3275069 [IM]Received Write request
I: 3275125 [EM]<<< [E:22185r S:57612 M:242209827 (Ack:53306798)] (S) Msg TX from C2032ACD15199E15 to 1:042B599B7E1E363B [FAE5] [UDP:[fd41:8102:3c8a:1:3040:80ff:1261:2b27]:54369] --- Type 0001:07 (IM:WriteResponse) (B:62)
I: 3275146 [EM]??1 [E:22185r S:57612 M:242209827] (S) Msg Retransmission to 1:042B599B7E1E363B in 1871ms [State:Active II:500 AI:300 AT:4000]
I: 3275159 [EM]>>> [E:22186r S:57612 M:53306799] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0001:03 (IM:SubscribeRequest) (B:56)
D: 3275175 [IM]Received Subscribe request
I: 3275179 [IM]Deleting previous subscription from NodeId: 042B599B7E1E363B, FabricIndex: 1
I: 3275187 [DMG]Subscription id 0xdac110e5 from node <042B599B7E1E363B, 1> torn down
I: 3275195 [DMG]Final negotiated min/max parameters: Min = 0s, Max = 30s
I: 3275202 [EM]<<< [E:22186r S:57612 M:242209828 (Ack:53306799)] (S) Msg TX from C2032ACD15199E15 to 1:042B599B7E1E363B [FAE5] [UDP:[fd41:8102:3c8a:1:3040:80ff:1261:2b27]:54369] --- Type 0001:05 (IM:ReportData) (B:77)
I: 3275222 [EM]??1 [E:22186r S:57612 M:242209828] (S) Msg Retransmission to 1:042B599B7E1E363B in 1840ms [State:Active II:500 AI:300 AT:4000]
I: 3275236 [EM]>>> [E:22185r S:57612 M:53306800 (Ack:242209827)] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
I: 3275254 [EM]>>> [E:22186r S:57612 M:53306801 (Ack:242209828)] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0001:01 (IM:StatusResponse) (B:42)
I: 3275269 [IM]Received status response, status is 0x00
I: 3275275 [EM]<<< [E:22186r S:57612 M:242209829 (Ack:53306801)] (S) Msg TX from C2032ACD15199E15 to 1:042B599B7E1E363B [FAE5] [UDP:[fd41:8102:3c8a:1:3040:80ff:1261:2b27]:54369] --- Type 0001:04 (IM:SubscribeResponse) (B:48)
I: 3275296 [EM]??1 [E:22186r S:57612 M:242209829] (S) Msg Retransmission to 1:042B599B7E1E363B in 1875ms [State:Active II:500 AI:300 AT:4000]
I: 3275308 [DMG]Registered a ReadHandler that will schedule a report between system Timestamp: 0x000000000031FA2C and system Timestamp 0x0000000000326F5C.
I: 3275327 [EM]>>> [E:22186r S:57612 M:53306802 (Ack:242209829)] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
I: 3275347 [EM]>>> [E:22187r S:57612 M:53306803] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0001:02 (IM:ReadRequest) (B:48)
D: 3275360 [IM]Received Read request
I: 3275367 [EM]<<< [E:22187r S:57612 M:242209830 (Ack:53306803)] (S) Msg TX from C2032ACD15199E15 to 1:042B599B7E1E363B [FAE5] [UDP:[fd41:8102:3c8a:1:3040:80ff:1261:2b27]:54369] --- Type 0001:05 (IM:ReportData) (B:408)
I: 3275387 [EM]??1 [E:22187r S:57612 M:242209830] (S) Msg Retransmission to 1:042B599B7E1E363B in 1859ms [State:Active II:500 AI:300 AT:4000]
I: 3275401 [EM]>>> [E:22188r S:57612 M:53306804] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0001:03 (IM:SubscribeRequest) (B:99)
D: 3275417 [IM]Received Subscribe request
I: 3275421 [IM]Deleting previous subscription from NodeId: 042B599B7E1E363B, FabricIndex: 1
I: 3275431 [DMG]Subscription id 0x2b87e0b0 from node <042B599B7E1E363B, 1> torn down
I: 3275439 [DMG]Final negotiated min/max parameters: Min = 0s, Max = 30s
I: 3275447 [EM]<<< [E:22188r S:57612 M:242209831 (Ack:53306804)] (S) Msg TX from C2032ACD15199E15 to 1:042B599B7E1E363B [FAE5] [UDP:[fd41:8102:3c8a:1:3040:80ff:1261:2b27]:54369] --- Type 0001:05 (IM:ReportData) (B:77)
I: 3275467 [EM]??1 [E:22188r S:57612 M:242209831] (S) Msg Retransmission to 1:042B599B7E1E363B in 1850ms [State:Active II:500 AI:300 AT:4000]
I: 3275481 [EM]>>> [E:22187r S:57612 M:53306805 (Ack:242209830)] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
I: 3275518 [EM]>>> [E:22188r S:57612 M:53306806 (Ack:242209831)] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0001:01 (IM:StatusResponse) (B:42)
I: 3275533 [IM]Received status response, status is 0x00
I: 3275539 [EM]<<< [E:22188r S:57612 M:242209832 (Ack:53306806)] (S) Msg TX from C2032ACD15199E15 to 1:042B599B7E1E363B [FAE5] [UDP:[fd41:8102:3c8a:1:3040:80ff:1261:2b27]:54369] --- Type 0001:04 (IM:SubscribeResponse) (B:48)
I: 3275559 [EM]??1 [E:22188r S:57612 M:242209832] (S) Msg Retransmission to 1:042B599B7E1E363B in 1887ms [State:Active II:500 AI:300 AT:4000]
I: 3275572 [DMG]Registered a ReadHandler that will schedule a report between system Timestamp: 0x000000000031FB34 and system Timestamp 0x0000000000327064.
I: 3275588 [EM]>>> [E:22188r S:57612 M:53306807 (Ack:242209832)] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
I: 3275637 [EM]>>> [E:22189r S:57612 M:53306808] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3275650 [IM]Received Read request
I: 3275655 [EM]<<< [E:22189r S:57612 M:242209833 (Ack:53306808)] (S) Msg TX from C2032ACD15199E15 to 1:042B599B7E1E363B [FAE5] [UDP:[fd41:8102:3c8a:1:3040:80ff:1261:2b27]:54369] --- Type 0001:05 (IM:ReportData) (B:190)
I: 3275675 [EM]??1 [E:22189r S:57612 M:242209833] (S) Msg Retransmission to 1:042B599B7E1E363B in 1872ms [State:Active II:500 AI:300 AT:4000]
I: 3275706 [EM]>>> [E:22189r S:57612 M:53306809 (Ack:242209833)] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
I: 3275878 [EM]>>> [E:22190r S:57612 M:53306810] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3275891 [IM]Received Read request
I: 3275896 [EM]<<< [E:22190r S:57612 M:242209834 (Ack:53306810)] (S) Msg TX from C2032ACD15199E15 to 1:042B599B7E1E363B [FAE5] [UDP:[fd41:8102:3c8a:1:3040:80ff:1261:2b27]:54369] --- Type 0001:05 (IM:ReportData) (B:70)
I: 3275916 [EM]??1 [E:22190r S:57612 M:242209834] (S) Msg Retransmission to 1:042B599B7E1E363B in 1870ms [State:Active II:500 AI:300 AT:4000]
I: 3276001 [EM]>>> [E:22190r S:57612 M:53306811 (Ack:242209834)] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
I: 3279139 [EM]>>> [E:22191r S:57612 M:53306812] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3279152 [IM]Received Read request
I: 3279157 [EM]<<< [E:22191r S:57612 M:242209835 (Ack:53306812)] (S) Msg TX from C2032ACD15199E15 to 1:042B599B7E1E363B [FAE5] [UDP:[fd41:8102:3c8a:1:3040:80ff:1261:2b27]:54369] --- Type 0001:05 (IM:ReportData) (B:70)
I: 3279177 [EM]??1 [E:22191r S:57612 M:242209835] (S) Msg Retransmission to 1:042B599B7E1E363B in 1861ms [State:Active II:500 AI:300 AT:4000]
I: 3279198 [EM]>>> [E:22191r S:57612 M:53306813 (Ack:242209835)] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
I: 3279515 [EM]>>> [E:22192r S:57612 M:53306814] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3279528 [IM]Received Read request
I: 3279533 [EM]<<< [E:22192r S:57612 M:242209836 (Ack:53306814)] (S) Msg TX from C2032ACD15199E15 to 1:042B599B7E1E363B [FAE5] [UDP:[fd41:8102:3c8a:1:3040:80ff:1261:2b27]:54369] --- Type 0001:05 (IM:ReportData) (B:70)
I: 3279555 [EM]??1 [E:22192r S:57612 M:242209836] (S) Msg Retransmission to 1:042B599B7E1E363B in 1899ms [State:Active II:500 AI:300 AT:4000]
I: 3279568 [EM]>>> [E:22193r S:57612 M:53306815] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3279584 [IM]Received Read request
I: 3279588 [EM]<<< [E:22193r S:57612 M:242209837 (Ack:53306815)] (S) Msg TX from C2032ACD15199E15 to 1:042B599B7E1E363B [FAE5] [UDP:[fd41:8102:3c8a:1:3040:80ff:1261:2b27]:54369] --- Type 0001:05 (IM:ReportData) (B:70)
I: 3279610 [EM]??1 [E:22193r S:57612 M:242209837] (S) Msg Retransmission to 1:042B599B7E1E363B in 1831ms [State:Active II:500 AI:300 AT:4000]
I: 3279624 [EM]>>> [E:22192r S:57612 M:53306816 (Ack:242209836)] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
I: 3279643 [EM]>>> [E:22194r S:57612 M:53306817] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0001:02 (IM:ReadRequest) (B:51)
D: 3279656 [IM]Received Read request
I: 3279660 [EM]<<< [E:22194r S:57612 M:242209838 (Ack:53306817)] (S) Msg TX from C2032ACD15199E15 to 1:042B599B7E1E363B [FAE5] [UDP:[fd41:8102:3c8a:1:3040:80ff:1261:2b27]:54369] --- Type 0001:05 (IM:ReportData) (B:70)
I: 3279680 [EM]??1 [E:22194r S:57612 M:242209838] (S) Msg Retransmission to 1:042B599B7E1E363B in 1852ms [State:Active II:500 AI:300 AT:4000]
I: 3279694 [EM]>>> [E:22193r S:57612 M:53306818 (Ack:242209837)] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
I: 3279712 [EM]>>> [E:22194r S:57612 M:53306819 (Ack:242209838)] (S) Msg RX from 1:042B599B7E1E363B [FAE5] to C2032ACD15199E15 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
What version is the iPhone running? There is an issue that is supposedly fixed in 18.4.
Thank you for reply!
My ios version is 18.3.2
I update iOS to 18.4. Things becoming odd. When I scan the QR-code with Smartthings app. It stuck on the “Processing…” page. After a while, report as below:
I test this in China. I’m wondering if there is location restriction or other reason cause this?
I change the region to United States. It start to commission, but still failed at the same point as iOS 18.3.2
I have the same problem on iOS 18.4.1. I was able to use my Android to add the matter device to smartthings but could not use iOS.
Hi @xiaoda_hu, what hub are you using?
We do face the same problem with two devices running Smart Things App V 1.7.33, both iphone 11 (IOS 18.5) and iPhone SE (IOS 18.5) but I found a workaround that works for us:
The problem only happened to us if the Aeotec Hub V3 was connected to the Internet via LAN. After we connected the Aeotec Hub V3 to the Internet via Wifi, all problems were gone and we are now able to flexible add or delete matter over thread devices both via android and ios.
maybe that helps
It seems that the issue is related to the Matter device having been previously added to the system. You need to remove the existing information and reset the Matter device. After that, the Matter commissioning should succeed.
Steps to remove the existing Matter device information on iOS:
Go to Settings → General → Matter Accessories,
select the corresponding device, and choose Remove.
maco via SmartThings Community <notifications@smartthings.discoursemail.com> 于2025年7月8日周二 14:40写道:
Thanks for your response. I also had this experience. In my case I can confidently say that I connected the Sensor the first time. So there seems to be multiple points to check to make smart things on IOS running smoothly.
@xiaoda_hu @all
We still had the described problem at two smart home systems with Aeotec V3 Hubs. But since we updated the ios devices to the newest IOS18.6.2 that was released by apple on the 20th of August 2025, all pairing issues were gone
Hope this information also helps the community.
Best Regards from Salzburg
I question why Samsung can’t resolve this issue by now. What’s stranger is that I just got a new Meross Matter sensor, and it added fine, but then failed repeatedly when I attempted to remove, reset, and add again because it stopped interacting with the automation. Since I have two devices, where one was still unconfigured, I tried that, but it fails also. I then found my old Samsung tablet, but have not had any success adding on that, as I get the same error when trying to connect to a thread hub.
