Making Xiaomi Motion Sensor a Super Motion Sensor
Hey peeps’,
Tried it on the Mi version R4, with great succes.
Instead of soldering i used silver PCB repair glue, just a tiny bit between TP14 and the switch (see picture).
Result: Immediate sees occupancy and after 6 seconds it’s cleared a new situation is already discovered.
can anyone tell how it goes in the long run?
What is the battery life of modified devices , any other downsides ?
I did the same with a pencil, graphite allows enough electricity to pass through
Anyone knows what hardware mod needs this new sensor? Thanks!
what do you mean by new sensor. new models have 1s cool down out of the box
Not in my case. My DJT11LM is still 60 seconds…
your sensor Xiaomi DJT11LM control via MQTT | Zigbee2MQTT
is the vibration sensor(not PIR) and the cool-down is likely software, contact your device driver provider
Can you guys please report how is the battery life after this mod?
@lifeisfun It last long more than one years
Thank you for the feedback! :slight_smile:
what driver are you using? having issues with mine vibration sensor - it registers only movements and not vibrations here ((
Hi @XMAS, I stopped using that device a few years ago when the drivers were still using Groovy, not Edge based drivers. I’m now using an ST multi-sensor that’s a couple years old.
