i search for hacking any remote control with arduino shield and i find this link…Hacking ‘any’ Remote Control with the SmartThings Arduino Shield. danny@smartthings.com…but its an old link b/c with the new forum i can not find it. does this page still exist? im buying some under cabinet lighting that comes with a remote and i would like to control it. instead of buying a relay…maybe disect remote and connect to arduino & st shield.
You may be able to find the page via Google cached sites, but I was unable to easily.
It’s a rather simple mod. You use the Arduino to bridge the points of two pins, in this case, the pins are the two leads on a single remote contact point. You can probably use the on/off shield device handler/Arduino sketch to send the command to the Arduino to turn them on and off (you’ll probably have to make some slight modifications since the Arduino is only sending a momentary pulse and not a consistent on/off toggle.
If i find an article on this, I’ll link it.
Good luck on your project.
Also, if you’re simply controlling a LED strip that comes with a remote, you can use Fibaro’s RGB controller. Haven’t tried it myself though: http://www.fibaro.com/en/the-fibaro-system/rgbw-controller
Hey @thegibertchan, did you ever find the article above, I know this an old topic but I’m interested and can’t find it anywhere. I bookmarked it a while back but I guess it was removed. It was for a Somfy system in one of ST’s offices.
