org.springframework.jdbc.UncategorizedSQLException: Hibernate operation: could not execute query; uncategorized SQLException for SQL [select this_.id as id110_0_, this_.version as version110_0_, this_.date_created as date3_110_0_, this_.key
as key4_110_0_, this_.type as type110_0_, this_.value as value110_0_ from server_config this_ where this_.key
=?]; SQL state [null]; error code [0]; [SimpleAsyncTaskExecutor-24] Timeout: Pool empty. Unable to fetch a connection in 30 seconds, none available[size:50; busy:0; idle:0; lastwait:30000].; nested exception is org.apache.tomcat.jdbc.pool.PoolExhaustedException: [SimpleAsyncTaskExecutor-24] Timeout: Pool empty. Unable to fetch a connection in 30 seconds, none available[size:50; busy:0; idle:0; lastwait:30000]. @line 1764 (motionEvtHandler)
@yvesracine, you are not the only one. It started first in last December and seems to resurface again.
