Is there a z wave in- wall combo light and fan switch? Light that can be dimmed and fan control for three speeds? Thanks.
I found this one. But doesn’t appear to be a smart switch.
You can use the double tap option on the GE fan control switch, but it’s not intuitive, and it would only give you on and off for the lights, not a dim.
The following FAQ lists the other fan options that are available. None of them match exactly what you described, but there might be something you could use.
