I currently have 12/3 wire running from switches(dual rockers) to each light/fan in my home. Are there any compatible controllers that will operate all functions (Light-OFF/ON/DIM + Fan-OFF/LOW/MED/HIGH)? Dimming is a plus, not a deal-breaker. Fan speed IS a must though.
Ideally I would like to replace the rockers with smart switches, as well as control via app/Echo.
[quote=“bradlee_s, post:1, topic:59444, full:true”]Any chance someone has found such a device yet?
Ideally I would like to replace the rockers with smart switches, as well as control via app/Echo.[/quote]
I use these in pairs for my 3-speed ceiling fan+light fixtures:
Ah, I’m sorry…I missed that part of your description. Yeah, that’s a problem.
Correct. So long as the fan is 3-speed capable, it works. ST treats it as a dimmer, so you use %s to target the speeds (which are roughly 0%-33%, 34%-66% and 67%-100%…give or take 1%).
You could pretty easily just cut the old box out by running a saw between the drywall cutout and the side of the box and replace with a double gang old work box. That is how I added fan switches.
There is a very similar topic to yours that has helpful information you might find interesting. They are also trying to do the fan/light work around with only 1 switch.
I have done something similar to this and rather than double post it’s easier to direct you there.
