They just came in today…I will be doing more of an extensive review if people are interested but in the mean time here are some initial first impressions. The kit I received is for the White LEDs (not the color ones) and has two modes, cool white, and warm white. It is also supposed to be brighter than the RGB model.
The product packaging is professional looking, and well done.
instructions are put together very well, even if there are a couple things that need fixing (such as numerous references to sections that don’t exist)
Setup was very easy, although I only setup the remote and haven’t tried the app yet
Speaking of the remote, it’s pretty slick and feels high quality, also the bulbs respond instantly to it with no hint of lag
When I first powered one up I was concerned as it was very blue, but I quickly discovered that was the “cool white” mode, and the warm light is better than I expected it to be. It has a yellowish traditional bulb hue to it.
They are not as bright as I hoped they would be. They are supposed to be as bright as a traditional 60 watt bulb…but I did not personally find that to be the case. They are even a little on the dim side to use in a beside lamp for reading (I confirmed it was set to full brightness)
Due to the brightness issue I really am not sure where I will be able to use them. I was going to give them a shot on the bedroom ceiling fan as it sits lower than the canned lighting through the rest of the house and would be a better fit for them…but I just discovered it uses those bulbs that have that really small screw flange on them.
If people are interested I can take some pictures, and a video or two showing their operation.
