Is it possible to setup a schedule with different color lights for different days with the Lightify Gardenspot Mini’s lights?
There has been some discussion at this thread here. One of the options is to have a custom DTH (Device Type Handler) to allow for color looping.
You could use the CORE app. Write a piston to do what you want and when. I think if you go to the thread posted you’ll see examples of using core to control them.
Or 7 SmartLighting automations. Set color red on Monday only. Set color blue on Tuesday only. It gets crazy thats true…and the color picker sucks in SmartLighting. But hey…it can be done.
Thanks. I think I got the Core thing setup correctly. We shall see at 6:30 pm what happens. Lol. If not I’ll give the others a try
If it doesn’t work right, keep trying, go to the CoRE user help thread and ask for help. The thread is HUGE and a jumbled mess but hopefully someone will jump in with a quick answer.
Yeah i browsed the thread and saw the mess. Thanks I’ll post there if it doesn’t work
I setup some color changing and some color loop pistons in CoRE. I found works better if you change the DTH also. But unlike others in actually using a RGBW handler that was made for the osram A19’s and works pretty well. Has the color loop command built in which works great!
