You must replace all the switches. Networked switches are not wired the same way as non-networked switches and need auxiliaries which are specifically designed to work with their model. See the FAQ:
There are two different auxiliary switches that Leviton makes that can work with the DZS15, but it depends on your exact setup.
Just follow the manufacturer’s instructions on the following page . If you don’t understand them, get in touch with Leviton support and they will help you select the right auxiliary.
