Knock on garage door to open?
I would be willing to compensate a dev if they could make me a smartapp which would trigger a switch when a multisensor detected vibration/movement.
These already exist, but reliability varies a lot depending on local architecture. Some people find they were great, some get a lot of false opens, Some get a lot of failed to detects.
Search the forums for “knock” and you should find different existing projects.
http://blog.smartthings.com/news/roundups/2-new-smartapps/
BTW, if you just wanted to trigger based on movement, you can already do that with the standard smart lights automations.
The knock detection is based on a different capability, “acceleration.”
So when you’re looking, it helps to distinguish between acceleration and motion to make sure you get what you want.
@tgauchat
Thanks JD,
I’m not sure if.one of the existing projects would work for my situation. I think there would be a lot of issues with the sensor detecting acceleration after knocking when the door starts to move, and then triggering it again. Or, when I open the door manually with the clicker.
