No direct integration, but you should be able to set up scenes in the KnightsBridge app and then use an Alexa routine as an intermediary to trigger a scene.
The problem is it the method for doing this relies on custom groovy code and custom groovy code will be going away in a few months. And we don’t yet know if there will be a replacement for the type of virtual sensor that you need to make this work.
FAQ: Can I trigger an Echo Action without Speaking to It?
The problem is that the method for doing this relies on custom groovy code and custom groovy code will be going away in a few months. And we don’t yet know if there will be a replacement for the type of virtual sensor that you need to make this work.
So I don’t know if there will be a long-term solution, but there is a short term one if it’s somewhat tedious.
