Hi, I’m looking to integrate my wifi lights and the knightbridge app does not plug into smartthings, does anyone have a work around or know how to do this?
No direct integration, but you should be able to set up scenes in the KnightsBridge app and then use an Alexa routine as an intermediary to trigger a scene.
The problem is it the method for doing this relies on custom groovy code and custom groovy code will be going away in a few months. And we don’t yet know if there will be a replacement for the type of virtual sensor that you need to make this work.
The problem is that the method for doing this relies on custom groovy code and custom groovy code will be going away in a few months. And we don’t yet know if there will be a replacement for the type of virtual sensor that you need to make this work.
So I don’t know if there will be a long-term solution, but there is a short term one if it’s somewhat tedious.
Thanks JDRoberts, I will give it a try.
I have asked Knightsbridge if they intend to integrate the app with SmartThings and will post their reply here for reference.
Update: for anyone interested, Knightbridge has no plan to come on board with Smartthings but I did find the lights work with Smart Life app and playing with some suggestions from other users using scenes to make the lights work with SmartThings.
