Hi
I purchased and connected a 36V LED light to my Smartthings Station (firmware v000.054.00013), but it seems to have a problem.
The problematic LED driver is the Aqara Smart Dimmer Controller T1 pro and the light flashes every 5-10 seconds.
The controller’s status LED is also flashing at the same time, so when I checked the logs in the Smartthings CLI, I got the following status change log when the light is flashing. (I think it’s because the hub can’t change the status, so it keeps trying, and when I change the colour temperature in the app, it flashes and goes back to 5000K).
Does anyone have a solution to this? (I’ve tried deleting and re-registering the device in the IDE and it’s the same, I’ve done it several times and sometimes it doesn’t happen, but when I turn off the power to the device it flashes again).
– CLI logs , comes out every time the light blinks—
2024-11-07T22:41:51.102792123+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> received lifecycle event: infoChanged
2024-11-07T22:41:51.154308127+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> received lifecycle event: doConfigure
2024-11-07T22:41:51.181433562+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x38BF, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 54EF441000D67A50, src_endpoint: 0x01, cluster: ColorControl, dest_addr_mode: 0x03, dest_address: 287681FFFEA159EF, dest_endpoint: 0x01 > > >
2024-11-07T22:41:51.264713598+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x38BF, dest_endpoint: 0x01, profile: 0x0104, cluster: ColorControl >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0007, DataType: Uint16, minimum_reporting_interval: 0x0001, maximum_reporting_interval: 0x0E10, reportable_change: 0x0010 > > > >
2024-11-07T22:41:51.385293950+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x38BF, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 54EF441000D67A50, src_endpoint: 0x01, cluster: OnOff, dest_addr_mode: 0x03, dest_address: 287681FFFEA159EF, dest_endpoint: 0x01 > > >
2024-11-07T22:41:51.508276875+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x38BF, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Boolean, minimum_reporting_interval: 0x0000, maximum_reporting_interval: 0x012C > > > >
2024-11-07T22:41:51.664506814+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x38BF, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 54EF441000D67A50, src_endpoint: 0x01, cluster: Level, dest_addr_mode: 0x03, dest_address: 287681FFFEA159EF, dest_endpoint: 0x01 > > >
2024-11-07T22:41:51.751431856+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x38BF, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Uint8, minimum_reporting_interval: 0x0001, maximum_reporting_interval: 0x0E10, reportable_change: 0x01 > > > >
2024-11-07T22:41:51.894880504+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x38BF, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xFCC0 >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x04, mfg_code: 0x115F, seqno: 0x00, ZCLCommandId: 0x02 >, < WriteAttribute || < AttributeRecord || attr_id: 0x0009, DataType: Uint8, data: 0x01 > > > >
2024-11-07T22:41:51.927226214+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x38BF, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x02 >, < WriteAttribute || < AttributeRecord || attr_id: 0x0012, DataType: Uint16, data: 0x0000 > > > >
2024-11-07T22:41:52.001851222+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x38BF, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x02 >, < WriteAttribute || < AttributeRecord || attr_id: 0x0013, DataType: Uint16, data: 0x0000 > > > >
2024-11-07T22:41:52.371344827+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x38BF, dest_endpoint: 0x01, profile: 0x0104, cluster: ColorControl >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x0A >, < MoveToColorTemperature || color_temperature_mireds: 0x00C8, transition_time: 0x0000, options_mask: 0x00, options_override: 0x00 > > >
2024-11-07T22:41:52.468355067+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x38BF, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2024-11-07T22:41:52.515192298+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x38BF, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2024-11-07T22:41:52.673141023+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x38BF, dest_endpoint: 0x01, profile: 0x0104, cluster: ColorControl >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0007 > > >
2024-11-07T22:41:52.820659446+09:00 DEBUG Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> doConfigure callback did not fail, transitioning device to "PROVISIONED"
2024-11-07T22:41:52.922106362+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x38BF, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFF, rssi: -56, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x0C >, < BindRequestResponse || status: 0x00 > > >
2024-11-07T22:41:53.126096841+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x38BF, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ColorControl >, lqi: 0xFF, rssi: -56, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x78, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || ZclStatus: SUCCESS > > >
2024-11-07T22:41:53.465483111+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x38BF, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFF, rssi: -54, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x0D >, < BindRequestResponse || status: 0x00 > > >
2024-11-07T22:41:53.600838402+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x38BF, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -55, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x79, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || ZclStatus: SUCCESS > > >
2024-11-07T22:41:53.637638005+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x38BF, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFF, rssi: -56, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x0E >, < BindRequestResponse || status: 0x00 > > >
2024-11-07T22:41:53.673276251+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x38BF, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, lqi: 0xFF, rssi: -56, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x7A, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || ZclStatus: SUCCESS > > >
2024-11-07T22:41:53.718961124+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x38BF, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xFCC0 >, lqi: 0xFF, rssi: -56, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0C, mfg_code: 0x115F, seqno: 0x7B, ZCLCommandId: 0x04 >, < WriteAttributeReponse || ZclStatus: SUCCESS > > >
2024-11-07T22:41:53.756167195+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x38BF, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xFCC0 >, lqi: 0xFF, rssi: -56, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0C, mfg_code: 0x115F, seqno: 0xC8, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0009, DataType: Uint8, Uint8: 0x01 > > > >
2024-11-07T22:41:53.792032737+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x38BF, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, lqi: 0xFF, rssi: -56, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x7C, ZCLCommandId: 0x04 >, < WriteAttributeReponse || ZclStatus: SUCCESS > > >
2024-11-07T22:41:53.826047990+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x38BF, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, lqi: 0xFF, rssi: -56, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x7D, ZCLCommandId: 0x04 >, < WriteAttributeReponse || ZclStatus: SUCCESS > > >
2024-11-07T22:41:53.862903637+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x38BF, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ColorControl >, lqi: 0xFF, rssi: -54, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x7E, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x0A, ZclStatus: SUCCESS > > >
2024-11-07T22:41:53.899509403+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x38BF, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -54, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x7F, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Boolean, OnOff: false > > > >
2024-11-07T22:41:53.938550678+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"off"}}
2024-11-07T22:41:53.965764873+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x38BF, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, lqi: 0xFF, rssi: -55, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x00, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Uint8, CurrentLevel: 0x47 > > > >
2024-11-07T22:41:54.000170635+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> emitting event: {"attribute_id":"level","capability_id":"switchLevel","component_id":"main","state":{"value":28}}
2024-11-07T22:41:54.025782712+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x38BF, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ColorControl >, lqi: 0xFF, rssi: -56, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x01, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0007, ZclStatus: SUCCESS, DataType: Uint16, ColorTemperatureMireds: 0x00C8 > > > >
2024-11-07T22:41:54.060393936+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> emitting event: {"attribute_id":"colorTemperature","capability_id":"colorTemperature","component_id":"main","state":{"value":5000}}
2024-11-07T22:41:54.084385896+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> received lifecycle event: infoChanged
2024-11-07T22:41:54.124190603+09:00 INFO Zigbee Switch <ZigbeeDevice: 485c85f9-51d1-448e-8cef-65f20cec19a5 [0x38BF] (Aqara Smart Dimmer Controller T1 Pro 2)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x38BF, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Basic >, lqi: 0xFF, rssi: -56, body_length: 0x0013, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0C, mfg_code: 0x115F, seqno: 0xC9, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0006, DataType: CharString, DateCode: "03-19-2024" > > > >
