@aquaria1984@Sticks18 Thank you guys. I just bought one and used your DH and everything seems working good. Thank you. If you release a new version, please share it here.
New to ST. Moved over from Wink for one reason because I bought this heater. I copied this code into a new DH and think I managed to configure everything correctly. When I added the new device ST recognized it. It seems to turn on if it’s off and seems to adjust the temperature up or down but ECO doesn’t seem to do anything and neither does the off switch. It also never shows the current temperature.
Any pointers? I’d really like to integrate this with my ecobee and have it come on when the ecobee comes on and turn off with the ecobee etc…
Unfortunately I am still having problems. I have a number of non-standard devices that I have had to import device handlers for, so I believe I am doing things right, however when I try to pair the Duraflame heater it shows up as a “thing” rather than a heater, etc, and allows me to add it, but then states that the tile is missing in the UX. Unable to control it at all. Any ideas what I could be missing?
Shows up in IDE as follows:
Zigbee Id 000D6F000BFDDA7F
Data
application: 00
endpointId: 01
manufacturer: Twin-Star International
model: 20QI071ARA
Raw Description 01 0104 0300 00 06 0000 0003 0201 0204 0702 0B02 03 0003 0019 0020
Firmware
Current Version: 0x07045700
Target Version: 0x07045700
I can see similarities and differences in the raw description, but I am unsure what the impact is.
I picked up the heater and used the latest DH found in this thread. The configure button doesn’t do anything. I am able to turn on / off and set the desired heat temp. I’d like to remove the cool mode and set point options since those are not applicable.
Are there any updates to the DH that address either of those. It’s not a major concern, just wanted to clean it up a bit. I suppose I can try to edit the DH and remove the functionality that doesn’t apply to this particular heater.
@Sticks18 Thanks for the DTH for the Iris Duraflame heater just brought one and hook it up to my SmartThings and it works good and would also like to thanks @aquaria1984 for helping out. You all make this the best community. Thanks you all very much.
I have another question just came up. I have the App set up to heat to 60 degree as a set point but the heater goes to 66 or 67? Is anyone else having this issue? If so, how do I correct it?
Sorry for the old thread, but I’m looking to get voice control on this with Google home. I’ve installed the device handler with the latest code I’ve found in this thread (thank you everyone for implementing it! :)), and after adding it to smartthings (came in as a thing) and changing the type to the handler it seems to work to change settings within smartthings but it doesn’t show up at all in Googles devices connected from smartthings. So it has no voice control. I’ve got two of these devices that I’d like to get connected and be able to control them with Google.
I’m fairly new to coding, but I am studying it in school, so any help is much appreciated.
On a much lower priority I’m noticing when I’m changing the temp setting with the remote that came with it that it takes a seemingly long time for the heater to update it’s temperature and to update it back in smartthings. There also seems to be a disconnect from the slide control to set the temperature to the box that I’m assuming only displays the set temperature. Those seem to hold different values for a rather long time. Again though, I’m new to programming and I could be completely wrong in my perception of time…
I’m also noticing that it is reporting values for power usage back to smart things (in watts? Didn’t realize it was that high…) And I’m wondering if it can display consumption in a similar fashion to the the smart plugs that also report power usage.
Thanks again for getting it working in the first place!
Hello. I have 4 of these heaters and am a refugee from IRIS where they worked beautifully. Thanks to this thread, I’ve gotten them close. They are connected. I can turn them off and on. When I go into the device in the ST app, I can see meters that show the power meter and temp. I can not however modify the temperature in the app. I just updated my device handler to be the one right above this from June 2018 and it’s still that way. Ultimately I want to be able to have them automatically go down to 60 overnight and then step up as time passes (which I know is all automations) but I can’t figure out how to tell it to set the temperature to any specific temp. I have an Echo and see that referenced a lot above for voice control. I can have it do the automation if that is how it rolls but hope there is a more elegant solution with SmartThings. HELP PLEASE!!
Quick update on that. After typing it, I tried changing it with the Echo and it worked. If it can’t be controlled directly within ST app then I can live with this but want to make sure I’m not over complicating my process with extra steps. Thanks and thanks to the device handler developer(s) who coded this.
New to SmartThings from Lowes Iris I’ve read all this about these codes and curious how do I go about implementing them to use the iris heater sorry if this is a stupid question just trying to learn thanks for everyone’s help in advance
Also I have the version 3 SmartThings if that matters
I’m kind of confused on how to do this I moved over to SmartThings from Iris I’ve imported the. Device Handler but I am unable to figure out how to get it to work could somebody do a step by step on how to do that hate to be any trouble I’m just confused
