vahaj
(Muhammad Wahaj uddin)
#1
Hi, I’m facing following error while define lambda ARN as schema connector. I have also correctly defined the following configuration from AWS cloud.
Client ID
Client Secret
Authorization URI
Token URI
Invalid input(s) used in request Invalid Lambda ARN… Failed to connect to partner lambda ARN in us-east-1
nayelyz
(Developer Support Team)
#2
Welcome to the SmartThings Community, @vahaj!
Do you receive that error when trying to register your Lambda function in the Developer Workspace?
In the post below, I shared a list of things we need to verify in that step:
About this configuration, is this for your OAuth server?
vahaj
#3
@nayelyz Thanks it worked.
