bangali
(the rooms manager guy)
January 18, 2021, 12:32am
1
input type time that used to work fine seems to be not working in my custom apps. in app settings time input params type are showing as blank instead of as time. trying to set a value does not seem to be working either and seems to cause the app to glitch.
so trying to figure out whats going on thought i would use this simple app below. when clicking on this app from SmartApps in the new ST app … it shows a “Something went wrong. Please try to install the SmartApp again.” popup and in the log its throwing this error:
error java.lang.RuntimeException: Metadata Error: Missing required page parameter 'name' @line -1 (pageTest)
what i am doing wrong and is there a know issue with input type time?
thank you.
* bangali test app
definition (
name: "bangali test app",
namespace: "bangali",
author: "bangali",
description: "bangali test app",
category: "SmartThings Labs",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png",
iconX3Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png"
preferences {
page(name:"pageTest", title: "Test Inputs")
def pageTest() {
dynamicPage(name:"bangaliTest", title:"bangali test", install:true, uninstall:true) {
section("Title") {
input "wakeupTime", "time", title:"Wakeup Time?", required: true, defaultValue: (wakeupTime ?: "07:00"), submitOnChange:true
input "sleepTime", "time", title:"Sleep Time?", required: true, defaultValue: (sleepTime ?: "22:00"), submitOnChange:true
def installed() {
log.debug "Installed with settings: ${settings}"
initialize()
def updated() {
log.debug "Updated with settings: ${settings}"
unsubscribe()
initialize()
log.debug "$wakeupTime | $sleepTime"
def initialize() {}
nayelyz
(SmartThings Developer Support)
January 18, 2021, 3:54pm
2
Hi, there!
This appears when the page name specified in preferences is not found. In your case, you only need to replace bangaliTest for pageTest here:
The Time input issue is already reported, it happens for iOS devices and our engineering team is already working on the fix (there’s not an ETA yet).
bangali
January 18, 2021, 5:38pm
3
duh … thanks for catching that.
is there a thread i can follow for updates?
also genuinely interested in knowing how does a ST app release get thru with this basic of a regression?
thank you.
nayelyz
January 18, 2021, 11:04pm
4
Actually, we don’t have a post related to this issue. It was reported to build@smartthings.com . If I receive an update, I’ll share it here with you.
bangali
January 19, 2021, 6:26am
6
is there also a known issue with submitOnChange:true? for example in the below test app setting each input sequentially from top to bottom am unable to set sleepTime after enabling sleep time toggle. havent tested other possible combinations.
and if cancel button is pressed sleepTime input value then gets highlighted like this:
from what i was seeing in my rooms manager app and then playing with this one its almost as if submitOnChange:true is both refreshing the current screen with all inputs and also instantiating a new copy of the current input setting to be accepted which then overlays the original onscreen.
* bangali test app
definition (
author: "bangali",
preferences {
page(name:"bangaliTest", title: "Test Inputs")
def bangaliTest() {
section("Title") {
input "wT", "bool", title:"Enable Wakeup Time?", required:true, defaultValue:false, submitOnChange:true
if (wT)
input "wakeupTime", "time", title:"Wakeup Time?", required:true, defaultValue:"07:00", submitOnChange:true
else
paragraph 'Wakeup TIme?' + '\nenable wakeup time to set'
input "sT", "bool", title:"Enable Sleep Time?", required:true, defaultValue:false, submitOnChange:true
if (sT)
input "sleepTime", "time", title:"Sleep Time?", required:true, defaultValue:"22:00", submitOnChange:true
else
paragraph 'Sleep TIme?' + '\nenable sleep time to set'
def installed() {
initialize()
def updated() {
unsubscribe()
initialize()
def initialize() {}
thank you.
bangali
January 20, 2021, 12:25am
7
and since about this morning time based calculations like light levels and color temperatures have stopped working without me updating any code.
so it’s not just time input any more its also time values that have been entered previously.
nayelyz
January 20, 2021, 12:41am
8
I see what you mean, I’ve added this to the report.
Which SmartApp handles those events?
bangali
January 20, 2021, 2:06am
9
thank you.
nvm … i had messed up some other settings while trying to set the time range while dealing with that overlay on the settings screen.
bangali
January 31, 2021, 2:57pm
10
any word on fixing this? it’s been over 2 weeks now.
RBoy
January 31, 2021, 3:32pm
11
It’s been over 8 months now since it was first reported.
bangali
January 31, 2021, 10:15pm
12
even better! Samsung must be working a deal to get out of the ST business
RBoy
February 2, 2021, 11:03pm
13
The fix was deployed today
nayelyz
February 2, 2021, 11:33pm
14
That’s right, thanks @RBoy . @bangali , please, remember to select a solution, it can be the post above which specifies that the deployment was made.
bangali
February 3, 2021, 7:23pm
15
thats good to hear.
we sometimes end up venting about how badly Samsung is handling this transition in our responses to you in this forum. but you have also been doing the very best you can to respond to our questions on the new app within the constraints that you must be operating in.
so … thank you.
marked your response as the solution.
nayelyz
February 3, 2021, 7:39pm
16
Don’t worry, @bangali . We are receptive to all the feedback (positive and negative) and it doesn’t affect the guidance we provide to you. You are the first in line to experience these inconsistencies, so, we appreciate your dedication as well in providing the information we request.
