I have a number of IR devices (e.g. Alarm, Garage Door, etc).
I found Harmony Hub that seems to manage IR devices (not sure it would manage the previous two devices).
What is the community using? I have seen some custom projects but I am looking something simple out of the box.
Trying to put Z-wave or zegbee relays all the time is expensive and not efficient.
If you want something out of the box, the harmony hub is the best choice for you.
If your device is not supported by harmony and it uses IR, you can still add it using theses instructions:
@anon36505037 thanks for the shout out. I have actually also made an IR garage door opener. Maybe one day i’ll make it available for everyone. Here is a picture of the first prototype: IR Garage Door Opener
RF just means “radio frequency.” There are many different RF frequencies and protocols in use today. Zigbee is RF. Zwave is RF. WiFi is RF. Bluetooth is RF. 344 MHz is RF.
None of these can talk to each other.
You need to know the exact frequency and protocol being used before you can figure out whether it’s possible to find a bridge device to then talk to SmartThings. Which it may not be – – some RF devices use a manufacturer proprietary encoding.
If the user manual doesn’t say what the specific protocol and frequency are, assuming the device is sold in the United States it will have an FCC license number on the device somewhere. It may be on the back, it’s sometimes inside the battery compartment.
