Thanks so much, I set this up in Feb of this year (2016) and it’s still working perfectly.
I haven’t had to change anything, or touch it since I first set it up.
This is the relay I used:
Relay Shield for Particle Photon I²C 2-Channel SPDT 1-Amp Signal Relay with WiFi and USB Interface + 6 Programmable GPIO
As far as the FOB key, as long as it has exposed terminals, you can experiment with a wire by closing the circuit to simulate a button press.
Once you figure out which terminals to use, it’s easy. If the FOB doesn’t expose the terminals, then this solution won’t work for you.
Also, the FOB that I have had separate arm and disarm circuits, so that made it easy to ensure I was actually arming or disarming. Some FOBs may only have a single button to do both functions.
Good luck, I hope this helps and you are able to create what you need.
The Photon is what gives you the WiFi (Internet) connection, which gives you access to IFTTT so you can control it through a SmartThings IFTTT trigger.
Interesting. I have an old system in my home that built in 1997. Seems to work ok, but no FOB, wonder if there is a different way to connect directly to the panel.
I’d love to automate using existing hardware. I’ve looked into replacing the panel with a newer web capable one. Panels are relatively cheap, but the keypads are pretty expensive, especially since I would need 3 to replace all the current keypads.
