Any ideas for volume control that connects to ST so I can use ST to turn it off after a certain amount of time (already found a smartapp doe this)
The volume control switch will be inside. This would be used for outdoor speakers that are on the same source as indoor speakers. I want to make sure the speakers are off next time the music is turned on.
I already have the multi- zone setup to support this. Thanks
I am in the same boat as you and wondering if the relay worked for you. I have four rooms with speakers in the ceiling and want SmartThings to control which rooms are “on” and certain rooms “off”… if the relay worked do you have any tips? Thanks
