In wall Fan and light control
I am looking for a zwave inwall fan control that also has light control. The ceiling fan in the room has a light and I cannot seem to find a switch that does both. also does ST support that in app?
This is a popular question. No automated inwall switch exists to operate two independent loads, but you can use a dual relay wired in the fan canopy. The best solution so far is in the threads below. A better solution if possible is to re-wire the fan, so the light and fan controls are separate loads and can each have their own zwave switch (zwave fan switch can control 3 speeds, and either switch or dimmer for lights).
Hello so an option that you can use if you only have one hot line going to the fan would be to put a z-wave on off switch to replace the current wall switch and then you can do the following:
